Thanks for this info. I was having the same problem. Maybe you found another solution? When I set the resolution mode to Raw and removed interpolation, the graphics look really bad.
Another solution found is to put flags=1 in the sqlth_partitions table but this causes some values to be cut off because the bounding values cannot be found.
