Accepting a single tagPath or list of tagPaths into tags (for backward compatibility)
I recently needed to add support for reading a list of tagPaths rather than just a single tagPath in a template, but needed to keep backwards compatibility, and compatibility for existing view template instances that don't have the new list param at all.
This expression essentially creates a single list of tagPaths by combining a single tagPath string and the new list of tagPaths into one list and then subscribing to their values with tags.
For this template, the tagPaths are actually paths to a UDT instance and I needed to read a specific tag from them, so in the expression I also append the relative path to the tag as well.
Expression
tags(
forEach(
asPairs(
if(
{view.params.decorations.alarms.alarmSummaryAreaPath} != '',
asList({view.params.decorations.alarms.alarmSummaryAreaPath}),
asList()
), // if the param is '', present as an empty list, otherwise wrap it into a list
coalesce(
{view.params.decorations.alarms.alarmSummaryAreaPaths},
asList()
) // if the param is Null, present as an empty list
it() + '/Alarm Summary/Status'
Example of input values
alarmSummaryAreaPath:
"[tagProv]Path/To/Folder"
alarmsummaryAreaPaths:
"[tagProv]Path/To/Other Folder",
"[tagProv]Path/To/Other Other Folder"
The expression will subscribe to these tags:
"[tagProv]Path/To/Folder/Alarm Summary/Status",
"[tagProv]Path/To/Other Folder/Alarm Summary/Status",
"[tagProv]Path/To/Other Other Folder/Alarm Summary/Status"
