IP camera status - how to catch "Stream ended." status
Looks familiar.... If you look at the Usage Notes for my Image Streamer module, you'll see a formal version of this as a script module, suited to use in a binding. Allows you to copy camera view instances around without needing a separate timer component.
https://www.automation-pros.com/streamer/doc/
Also:
