Maker edition stuck on validation screen on jetson nano
this link brings me to a web page that says
message “Forbidden”
OK I was able to get the Ignition working with the 2 hour clock.How I dont know the last thing that happen was it was trying to connect where it usually hangs up.
Then the board froze up and then rebooted on its own and when it came back up I was able to acces the get started page
At least we got a beach head established
Maker is working now also.
Validation screen just take a couple seconds to validate.
Did you guys do something on your side
I work with ignition as a control Tech for my day job and I do a little work with Nvidia as a developer on the side. Once I get down the install procedure I am going to introduce ignition maker to the Nvidia Dev community
Here is the ticket to get the gateway to run on jetson nano.
Run this:/user/local/ignition/$ sudo ./ignition.sh install
Then reboot jetson nano
Then run this:/user/local/ignition/$ sudo ./ignition.sh status ( this just tells you the gateways running)
Then this http://localhost:8088 (to start ignition webpage.)
Then just follow instruction for which ever flavor of igniton you want.
Be patiant , the gateway takes about 15 to 20 sec to start
