Doesn’t R play well with Python, and therefore could be extended through Python in some way?
Possibly, but the purpose of this was to provide extensibility without adding another software package. Using R would require that you install-- and maintain-- it on every client and gateway that would use it. An import of the script is all that is necessary here.
Even then, it wasn’t a perfect solution. In Ignition 7.2, you still needed to import it for each project that required it. But now with 7.7, we now get globally shared scripting. One import per gateway. It’s even possible that some of the functions are now redundant, with the move to Jython 2.5.
Also, keep in mind that other libraries that would make it even easier to work with R, like Numpy, depend on being used with C-based components, and just won’t work with Jython.
Latest version is at top post.
During my few days off for vacation, I’ve added added another function: polyfit().
This is a polynomial regression model returning up to 5th degree coefficients. If you’ve ever had to do this by hand, you may remember having to do a lot of matrix maths. Considering I hadn’t had to do anything like that in 25 years, I had to relearn it. Not sure what fell out of my brain trying to cram all this back in, but that’s another problem for another time!
Usage: polyfit(x, y, [stringReturn])
Like linreg(), polyfit() requires the x and y coordinates to be in separate lists.
I tossed in an optional parameter called stringReturn to give you a polynomial expression. Is it useful? I have no idea, but if you find it useful, then I’m glad I could help.
That’s awesome, Jordan!
I use excel to plot and figure out polynomial expressions but this seems much easier…
Update to polyfit():
USAGE: polyfit(x,y,[order],[stringReturn])
x and y, as before are separate ordinate lists.
NEW option-- order: specify order of polynomial to return (default 2)
stringReturn-- optional parameter to return a string expression of the polynomial.
New functionality:
dec2bin(integer,bits,signed)
convert decimal to binary string representation.
Usage:
-integer: number to convert
-bits: number of binary bits to convert to. Default is 32.
-signed: returns a signed or unsigned binary representation. (Default is 1/True)
Returns: list [binary_string, bit_count]
Almost forgot the bit count! This is the number of ones in the binary representation.
New functionality:
fp2dec(number)
convert IEEE 754 floating point to decimal.
Usage:
-number: decimal representation of floating point number
Returns: decimal value.
Tested using examples from here.
I’ve started a function to go to IEEE 754, but I’m getting sleepy!
Hey guys, is there a way of plotting the linear regression line on an Easy Chart? i am able get the r² values etc.
Hi guys!
Latest version re-uploaded. Some of them have broken over time, so I fixed those as well. I think. Updated usage doc also uploaded.
I figured this is probably the more proper topic to post to with new functions…
Below is a function to calculate the median value of either a list, or an arbitrary number of arguments.
#returns median value
#accepts either a list of values, or a series of arguments
#if the first argument is a list, it only computes the median on that list
def median(*args):
if type(args[0]) == list:
data = args[0]
else:
data =[]
for i in args:
data.append(i)
new_list = sorted(data)
if len(new_list)%2 > 0:
return new_list[len(new_list)/2]
elif len(new_list)%2 == 0:
return (new_list[(len(new_list)/2)] + new_list[(len(new_list)/2)-1]) /2.0
Some example results from the function:
>>> print shared.math.median(1,2,3,4,5,9)
3.5
>>> print shared.math.median([1,2,3,4,5,9])
3.5
>>> print shared.math.median([0.145,2.14,50,2.299,30.21,5])
3.6495
>>> print shared.math.median("apple","orange","grape",8,10)
apple
The script does actually return the median value of a list of strings (or mixed string and numeric values, with the numbers being sorted ahead of the strings) if the number of items is odd. Predictably, the function blows up if there’s an even number of items that leads to trying to average two strings. I didn’t add a test for numeric values.
Hey Jordan,
I’m just trying to use the polyfit function, but I’m not getting the results i’m expecting
Any ideas before I try to step into the frying pan?
x = [1552920192, 1552938624, 1552961664] # datetimes in unix timestamp
y = [12.85043621, 12.4644804, 11.92448521]
a,b1,b2,b3 = shared.math.polyfit(x,y,order=3,stringReturn=False)
print r
def y(x, a,b1,b2,b3):
return b3*x**3 + b2*x**2 + b1*x + a
print y(1552920192, a,b1,b2,b3)
[10608.0, -4.2691826820373535e-06, 6.775829897165408e-15, -5.4057545500047475e-24]
74.2827997627 ## This should return ~12.85043621
This should return approximately y[0]
FYI I have removed your line that was rounding the coefficients in lines 349-360ish:
def polyfit(x,y,order=2,stringReturn=False):
assert(len(x)==len(y)), "Number of X ordinates do not match number of Y ordinates"
assert(order > 0 and order < 6), "Order must be between 1 and 5"
order += 1
sumX=shared.math.sum(*x)
x2=[]
for i in range(len(x)):
x2.append(x[i] * x[i])
sumX2=shared.math.sum(*x2)
x3=[]
x3.append(x[i] * x2[i])
sumX3=shared.math.sum(*x3)
x4=[]
x4.append(x2[i] * x2[i])
sumX4=shared.math.sum(*x4)
x5=[]
x5.append(x2[i] * x3[i])
sumX5=shared.math.sum(*x5)
x6=[]
x6.append(x3[i] * x3[i])
sumX6=shared.math.sum(*x6)
x7=[]
x7.append(x3[i] * x4[i])
sumX7=shared.math.sum(*x7)
x8=[]
x8.append(x4[i] * x4[i])
sumX8=shared.math.sum(*x8)
x9=[]
x9.append(x4[i] * x5[i])
sumX9=shared.math.sum(*x9)
x10=[]
x10.append(x5[i] * x5[i])
sumX10=shared.math.sum(*x10)
sumY=shared.math.sum(*y)
xy=[]
xy.append(x[i] * y[i])
sumXY=shared.math.sum(*xy)
x2y=[]
x2y.append(x2[i] * y[i])
sumX2Y=shared.math.sum(*x2y)
x3y=[]
x3y.append(x3[i] * y[i])
sumX3Y=shared.math.sum(*x3y)
x4y=[]
x4y.append(x4[i] * y[i])
sumX4Y=shared.math.sum(*x4y)
x5y=[]
x5y.append(x5[i] * y[i])
sumX5Y=shared.math.sum(*x5y)
matrix=[]
matrix.append([float(len(x)), sumX, sumX2, sumX3, sumX4, sumX5])
matrix.append([ sumX, sumX2, sumX3, sumX4, sumX5, sumX6])
matrix.append([sumX2, sumX3, sumX4, sumX5, sumX6, sumX7])
matrix.append([sumX3, sumX4, sumX5, sumX6, sumX7, sumX8])
matrix.append([sumX4, sumX5, sumX6, sumX7, sumX8, sumX9])
matrix.append([sumX5, sumX6, sumX7, sumX8, sumX9, sumX10])
vector=[sumY, sumXY, sumX2Y, sumX3Y, sumX4Y, sumX5Y]
inverse=[]
inverse.append([1.0,0.0,0.0,0.0,0.0,0.0])
inverse.append([0.0,1.0,0.0,0.0,0.0,0.0])
inverse.append([0.0,0.0,1.0,0.0,0.0,0.0])
inverse.append([0.0,0.0,0.0,1.0,0.0,0.0])
inverse.append([0.0,0.0,0.0,0.0,1.0,0.0])
inverse.append([0.0,0.0,0.0,0.0,0.0,1.0])
del matrix[order:]
del vector[order:]
del inverse[order:]
for i in range(order):
del matrix[i][order:]
del inverse[i][order:]
assert(matrix[i][i]!=0), "Invalid Matrix"
x=matrix[0][0]
matrix[0][i] = matrix[0][i] / x
inverse[0][i] = inverse[0][i] / x
for z in range(1,order):
for i in range(z,order):
x=matrix[i][z-1]
for j in range(order):
matrix[i][j]=matrix[i][j]-x*matrix[z-1][j]
inverse[i][j]=inverse[i][j]-x*inverse[z-1][j]
y=matrix[z][z]
matrix[z][j]=matrix[z][j] / y
inverse[z][j]=inverse[z][j] / y
for z in range(order-1,0,-1):
for i in range(0,z):
x=matrix[i][z]
matrix[i][j]=matrix[i][j]-x*matrix[z][j]
inverse[i][j]=inverse[i][j]-x*inverse[z][j]
y=matrix[z][z]
coefficient=[]
x = 0.0
x += inverse[i][j]*vector[j]
# Note: removed rounding from this next line to make more accurate
coefficient.append(x)
if stringReturn==False:
return coefficient
else:
s=''
for c in range(len(coefficient)-1,-1,-1):
if coefficient[c] != 0:
if c > 1:
s+= "%+.2fx^" % coefficient[c]+str(c)
elif c>0:
s += "%+.2fx" % coefficient[c]
else:
s += "%+.2f" % coefficient[c]
return s
The issue here (mostly ) is that it is diffucult to get a good regression from three data points.
You can do three things:
- Use many data points:
- Change the order magnitude:
a,b1,b2 = shared.math.polyfit(x,y,order=2,stringReturn=False)
def y2(x, a,b1,b2):
return b2*x**2 + b1*x + a
print '2nd order:', y2(1552920192, a,b1,b2)
def y3(x, a,b1,b2,b3):
print '3rd order:',y3(1552920192, a,b1,b2,b3)
a,b1,b2,b3,b4 = shared.math.polyfit(x,y,order=4,stringReturn=False)
def y4(x, a,b1,b2,b3,b4):
return b4*x**4 + b3*x**3 + b2*x**2 + b1*x + a
print '4th order:',y4(1552920192, a,b1,b2,b3,b4)
a,b1,b2,b3,b4,b5 = shared.math.polyfit(x,y,order=5,stringReturn=False)
def y5(x, a,b1,b2,b3,b4,b5):
return b5*x**5 + b4*x**4 + b3*x**3 + b2*x**2 + b1*x + a
print '5th order:',y5(1552920192, a,b1,b2,b3,b4,b5)
2nd order: 4.40191416635
3rd order: 74.2827997627
4th order: 18.3351743291
5th order: 16.1118623086
- Use polynomial interpolation. That’s attempts to find a polynomial that includes all the data points. It’s subtly different than regression, but it is different.
I am trying to find the coefficient of a curve on 2nd or 3rd degree using either 3 or 10 points then send coefficient to the plc so he can aveluate the curve according to live input.
Excuse my ignorance, can you guide me where to get thi module??
Thank you
Import it into a project. An empty on would be best.
Thank you. very nice and easy to use!! was struggling with this for a while!
Data match excel solution exactly. will have a look for other features, se if it can ease my math's even more!!
Hi,
Thank you for sharing this.
can you please guide to do total of column values in a power Table.
can we get this type of data by using sum function.
In this pic, they are calculating in between and last total.
Thank you
How is the data coming in? Since the dataset would have to be construced, we may as well iterate over the incoming data.
I recently posted a couple of examples of this here:
I think they were looking to have the intermediary sums in there as well. Not enough information to say one way or the other.
This is coming from database, I used query for the power table. Target column is coming from entry screen and storing in database. Actual column is calculated values.
Thank you, I am trying for the total to be print in between as in fig.
