All, I would like to thank everyone for helping me with this issue. I have found the solution and will leave it here for future reference.
I found 3 issues that was stopping communication:
Flakey Network Port
I can not get consentient pings to one of the 3 network ports. (The one labeled "For ModBus TCP" infuriatingly enough) I switched to another port and will reach out to manufacture for more info. -
Does not like to use ModBus TCP Slave ID 1.
For some reason this manufactures ModBus TCP stack doesn't like to talk to ignition when I use slave Id 1 so I have changed it to 255. No reason for 255, just that it is a easy number to remember. -
Polling Rate. The main issue (I think). Apparently the 1 second default polling rate in Ignition is not fast enough. The device is closing the connection before any ModBus commands are sent. I set one tag to be in a faster polling tag group (500 ms and set it to Polling rather than subscribed) and that was enough to keep the connection alive.
