Month in a query without month text
I may be about to toss some mud in the water.
You can create a temporary table using a custom function. This will run from the Database Query Browser.
create function dbo.YearMonths(@StartDate DateTime, @EndDate DateTime)
returns @YearMonths table
([YearInt] int,
[MonthInt] int,
[MonthFullName] varchar(20),
[MonthShortName] varchar(10))
as
begin
    set @EndDate = DATEADD(month, 1, @EndDate)
    while (@StartDate < @EndDate)
    begin
    insert into @YearMonths
    select YEAR(@StartDate), MONTH(@StartDate),  FORMAT(@StartDate,'MMMM yyyy'), FORMAT(@StartDate,'MMM yyyy')
    set @StartDate = DATEADD(month, 1, @StartDate)
    end
return
end
Sample output
SELECT *
FROM dbo.YearMonths(DATEADD(MONTH, -6, GETDATE()), DATEADD(MONTH, 6, GETDATE()))
returns
One of the tables I have is BOM information for production orders. Using this function with that table:
SELECT MonthFullName, qty
FROM (
	  SELECT COUNT(b.prod_order) as qty, y.MonthInt, y.YearInt, y.MonthFullName FROM bom b
	  FULL JOIN dbo.YearMonths(DATEADD(MONTH, -6, GETDATE()), DATEADD(MONTH, 6, GETDATE())) y on MONTH(b.t_stamp) = y.MonthInt
	  GROUP BY y.MonthInt, y.YearInt, y.MonthFullName, y.MonthFullName
	 ) t
ORDER BY YearInt, monthInt
returns
Note that this will also take care of any rollover between years.
If you need to modify the function, you can use
drop function dbo.YearMonths
modify the text, then execute it again to create it.
