Musson Industrial's Embr-Periscope Module
Release Notice
Embr v8.1 - 2026.3.3
Embr v8.3 - 2026.3.3
This release includes a scripting function for submitting functions to a Perspective session's queue:
system.perspective.invokeOnQueue(function, [delay], [scope], [sessionId], [pageId])
Parameters
  • function (required)
    A function that will be called with a single parameter:
    • The parameter is the requested scope.
    • This allows access to the view, page, or session if it cannot be captured via a closure.
  • delay (optional)
    Time in milliseconds to wait before invoking the function.
    • Allows scheduling functions to run later.
  • scope (optional)
    Controls the lifecycle of the function relative to Perspective objects. Default is 'view'.
    • 'view': Function runs only if the view is still active after the delay.
    • 'page': Function runs only if the page is still active after the delay.
    • 'session': Function runs only if the session is still active after the delay.
  • sessionId (optional)
    The target session ID.
  • pageId (optional)
    The target page ID.
Examples
Delayed Execution
def myFunction(scope):
    system.perspective.print("Running after 5 seconds. Neat.")
system.perspective.invokeOnQueue(myFunction, 5000) # default scope='view'
Incrementing Counter
This example counts to 50 using view custom properties.
def doThing(scope):
	if self.view.custom.count < 50:
		self.view.custom.count += 1
		self.view.custom.text = 'Counting: %d'  % self.view.custom.count
		system.perspective.invokeOnQueue(doThing, 100)
	else:
		self.view.custom.text = "Done!"
self.view.custom.count = 0
self.view.custom.text = "Waiting to start...."
system.perspective.invokeOnQueue(doThing, 1000)
Incrementing Counters (across all sessions)
This example counts to 50 using session custom properties. The functions will be run across all client sessions using scope='session' and sessionId parameters.
def makeHandlers(sessionId):
    def doThing(scope):
        if scope.custom.count < 50:
            scope.custom.count += 1
            scope.custom.text = scope.custom.count
            system.perspective.invokeOnQueue(doThing, 100, scope='session', sessionId=sessionId)
        else:
            scope.custom.text = "Done!"
    def setup(scope):
        scope.custom.count = 0
        scope.custom.text = "Waiting to start...."
        system.perspective.invokeOnQueue(doThing, scope='session', sessionId=sessionId)
    return setup
sessions = system.perspective.getSessionInfo()
for session in sessions:
	# Simple way to filter out designer sessions
    if len(session.id) < 36:
        continue
    setup = makeHandlers(session.id)
    system.perspective.invokeOnQueue(setup, 1000, scope='session', sessionId=session.id)
New Sponsors
Big thanks to both @David_Stone and @andrew.budaiev for sponsoring this project!
If you're interested in contributing, check us out on GitHub Sponsors.
