Nightly 8.0 Changelogs - 2020
Nightly Changelog: 8.0.9-b20200212
Ignition Platform
15761: Cannot delete custom property on tags
Fixed an issue where custom properties on tags could not be deleted.
Misc
15872: Disable User Source Cache if validation timeout setting is less than zero
On all user sources, the Cache Validation Timeout, Lockout Attempt, and Lockout Window properties can all now be disabled if set to a number less than zero.
Nightly Changelog: 8.0.9-b20200213
Ignition Platform
13361: Concurrent Users Designer Interface
Added the Concurrent Users interface to the Designer. This new UI allows users to see which resources are open in other Designers, as well as show when a project update is available.
15829: IllegalStateException when importing UDT instances
Fixed an issue where importing UDT instances would fail with an exception in cases where the instance did not contain a “dataType” property.
15501: Reference to OPC tag in direct tag group can cause leased subscriptions
Fixed an issue where OPC tags in Direct tag groups would occasionally get subscribed at a default “leased” rate regardless of tag group, depending on references to the tags.
OPC-UA
15819: Tags Are Showing Multiple Times In OPC Browser When Dairy Simulator Is Used
Removed duplicate tags in the programmable simulator’s “Dairy Simulator” program.
Nightly Changelog: 8.0.9-b20200214
Ignition Platform
15926: Include all device drivers for edge
Edge installers now include all device driver modules.
15949: Project scripts reloaded on license checks
Fixed an issue that caused project scripts to be reloaded multiple times on startup.
15783: launcher shortcut argument fixes, window mode fixes
Fixed an issue where clients launched via command line interface were ignoring init.heap and max.heap arguments.
13361 concurrent designer
OPC-UA
15187: Add system tags for device statuses
Each device connection on a gateway will now be represented with a new set of system tags, located at System/Gateway/Devices/%DeviceName%, providing a tag-based means of verifying device connection status.
Perspective
15195: barcode component
Barcode display component has been added, allowing for the display of 105 different types of barcodes.
No nightly for 2/18/2020 - we pushed out 8.0.9 to patch some issues.
No nightly for 2/19/2020
Still working on getting the 8.0.10 nightly builds together. No update for today.
Nightly Changelog: 8.0.10-b20200221
Enterprise Administration
13418: Fix EAM agent license page
Prevented an erroneous agent licensing expiration message from appearing on the Controller Agent Management details page.
Ignition Platform
13935: Value of built-in UDT parameters not updating when source data changes
Fixed an issue where built-in UDT parameters were not automatically updating their values.
15677: Consider valid JSON objects as normal values instead of param references
Fixed an issue where UDT members containing JSON-encoded strings were incorrectly treated as parameter references.
16023: fix a deadlock updating device system status tags
Prevents a deadlock in the internal database that could prevent gateway restarts.
15926 Include all device drivers for edge
15817: Cannot Write To Programmable Simulator Boolean Tags via Quick Client
Fixed an issue that prevented Quick Client writes to boolean tags in the Programmable Simulator
15953: Tag providers don’t clean up executor threads.
Fixed an issue where tag provider threads would not shut down upon provider shutdown/restart.
15840: refactored vision client startup to move project downloading after session initialization
Resolved information leak by required project download to require authentication
Misc
Iterate to java 11.0.6
Updated bundled JREs from 11.0.5 to 11.0.6
OPC UA
Added a set of system tags for each device connection, representing the status of the device. The tags can be found in the System Tag Provider at: System/Gateway/Devices/%DeviceName%.
Nightly Changelog: 8.0.10-b20200224
Ignition Platform
15734: Reduce red overlays when opening windows.
Reduces the occurrence of red “stale” or “error” overlays in situations where the initial subscription value has not yet arrived.
Misc
15796: Add optional gateway logging to system.perspective.print
Added new argument to system.perspective.print to specify the destination of the print message (client, gateway, or all)
Vision
15920: resolve IOUtils error, cleanup unwanted dependencies
Fixed a missing dependency error that occurred when launching a Vision Client.
15503: easy chart start time
When the start time is greater or equal to the end time for a query, the Easy Chart will no longer log an error and will bypass the cache altogether.
Nightly Changelog: 8.0.10-b20200225
Ignition Platform
15976: Notify gateway script project upon legacy upgrade
Fixed an issue where the ‘Gateway Scripting Project’ was not updating correctly during legacy upgrades.
Perspective
15993: NPE When Closing a Flex View While Deep Selected
Prevents an error that could occur when closing Perspective views while deep selected in a non-coordinate container.
Nightly Changelog: 8.0.10-b20200301
Approximate list; there’s a few more changes not listed. This will be the last nightly release of 8.0.10; 8.0.11 nightlies will be available starting tomorrow. 8.0.10 RC1 should be available soon.
16062: Edge History Sync configs lost during upgrade to 8.0.7+:
Fixed an issue where Edge History Sync settings would be lost on upgrade.
15787: Added functionality to copy client tags as XML text, and paste into a separate designer
16021: Margins and Padding support as style attributes
15011: Implement single and multiple subview expansion modes
Added a subviewExpansionMode property. When set to “single”, expanding one subview will automatically close all other expanded subviews.
15866: AST pager not updating correctly on mount, missing MobX reaction
Fixed an issue where the pager buttons on the Alarm Status Table component would not update correctly.
15748: Fix issues with DatasetExcelAdapter
Fixed an issue with system.dataset.toExcel when exporting multiple datasets.
15830: DatasetExcelAdapter#drawSheet liable to NPE when dataset contains nulls
Fixed an issue where system.dataset.toExcel would throw NullPointerExceptions when exporting datasets containing null data.
15920: NoSuchMethodError when starting Vision client
15950: Edge Sync alarms need to be able to use remote pipelines
Edge gateways with the Sync Services plugin may now use remote notification pipelines.
15503: ‘The start time is greater than or equal to the end time’ easy chart cache error
15796: Add second argument To system.perspective.print for optional Gateway logging
Reduces the occurrence of red “stale” or “errored” overlays in situations where the initial subscription value has not yet arrived.
15402: Writing a JSON encoded string to a UDT parameter results in a null value
Fixed an issue where writing JSON-encoded strings to UDT members were incorrectly treated as parameter references.
15677: UDT Members that have JSON as values are erroring out
15505: Add Local Audit Profile option to standard edition gateways
16045: Mark actions as ineligible while logging in or logging out
Fixed a potential race condition where logging in after logging out can cancel the logout in Perspective
16077: Expose a System Property for Session Cookie SameSite Attribute
System property ignition.http.session.cookie.same-site.enabled can be set to true in order to specify the SameSite attribute on Gateway session cookies (default is false). When the SameSite attribute is enabled, system property ignition.http.session.cookie.same-site.value can be used to set the value of the SameSite attribute. Acceptable values are Strict, Lax, and None (default is Strict). See https://developer.mozilla.org/en-US/docs/Web/HTTP/Headers/Set-Cookie for descriptions for how these values work in web browsers.
11901: Add countersigning to Windows executables
15995: Sluggish performance when loading page with many embedded views
Fixed issue that prevented progressive view loading, making navigation feel sluggish.
15977: Lookup expression returning error quality due to internal NPE
15777: DNP3 point subscriptions stop polling on disconnect
14029: jsonValues structure of dropped UDT instance shouldn’t be affected by the folder structure which it is contained
Nightly Changelog: 8.0.11-b20200303
16009: Launchers in pre-deploy config don’t copy launchclient.jar to users cache dir
15996: Launcher support for redirect.txt file in .ignition dir
Nightly Changelog: 8.0.11-b20200304
Ignition Platform
14460: Designer Login - Layout Redesign
12077: add system.project scripting space
Add system.project.getProjectNames() and duplicate system.util.getProjectName() into system.project.getProjectName()
15868: Accept table cell edit in dataset tag editor on value commit
Vision
9527: Add “scripting” to template node popup in project browser
Nightly Changelog: 8.0.11-b20200305
Ignition Platform
11643: system.util.sendMessage payloads are now sent as JSON text whenever possible
Prevented an error that could occur when sending messages from an 8.0 gateway to a Message Handler on a 7.9 gateway.
OPC-COM
16090: COM Tunneler throws NPE when sending array tags from particular server
Prevents an error that could occur in the COM Tunneler when sending array tags from a server.
Perspective
14771 signature pad
Added a Signature Pad component to Perspective, providing a way to capture a signature, and then do something (via scripting) to an image of the signature.
Nightly Changelog: 8.0.11-b20200306
Ignition Platform
16103: Fixed a missing override on legacy tag upgrade
Fixed an issue where upgrading from 7.9 to 8.0 would unintentionally change the value on memory tags.
OPC-COM
16090: COM Tunneler throws NPE when sending array tags from particular serverPrevents an error that could occur in the COM Tunneler when sending array tags from a server.
Perspective
14407: Implement default column sort order for all palette table components
Perspective’s Alarm Status Table now supports multiple sort orders. The order is first determined by the Sort Order property on the table. Additional sorting defined on column configurations will then be applied.
Nightly Changelog: Feature-b20200309
Ignition Platform
15440: Replace OSX installer icns file
Updated the OSX ICNS file seen when installing/upgrading.
16074: Perspective Module Restart can potentially create multiple ModuleClassLoaders
Fixed an issue where users are unable start up new Perspective sessions after a Perspective module restart when a Perspective session existed from before the module restart on the same HTTP Session.
Omron Driver(s)
16104: FINS: Cannot subscribe to non-value properties via OPC UA
The FINS driver will no longer attempt to subscribe to non-value properties via OPC UA.
Perspective
16002 reintroduce react resize detector to barcode component
Fixed an issue where QR barcodes (via the Barcode component) would not render in the View Canvas.
Nightly Changelog: 8.0.11-b20200310
Ignition Platform
16114: force sync to underlying storage when writing project files
Project changes made in the designer will now be synchronized to the local system, allowing the designer to retain recent changes even if the gateway connection is lost.
14623: Add “antialias” to the multi state button’s removed properties
Vision property bindings configured in 7.9 on “antialias” properties no longer throw exceptions after upgrading to 8.0
Perspective
16020: unregister support of permessage-deflate via system flag
Added a system property that can dictate if web socket compression (permessage-deflate) should be enabled or not. By default, compression is enabled. Compression can be disabled by setting the following JVM parameter: perspective.ws.disablePermessageDeflateExtension=true’.
Nightly Changelog: 8.0.11-b20200311
Ignition Platform
15620: Add system.db.runSFNamedQuery()
Added a system.db.runSFNamedQuery function. Providing a way to call a Named Query that runs in the Store and Forward system.
15707: Certain locales cause restarted UDT members to break.
Fixed an issue where restarting UDT members would fail in certain locales when the historical deadband setting is bound to a double, due to different locales using different decimal separator characters.
Perspective
15836: Chart Range Selector - Multiple data sources stack instead of overlay
Fixed an issue where stacked data sources could potentially render with incorrect values.
14899: file upload
The File Upload Component has been restyled to be more responsive, handling resizing more gracefully.
Nightly Changelog: 8.0.11-b20200312
Ignition Platform
15310: Add service to reset isShelved flag on alarms when expired
‘isShelved’ alarm properties are now updated appropriately when an alarm shelf expires.
Nightly Changelog: 8.0.11-b20200313
Ignition Platform
15602: Web Config UI for Omron Fins Tag Definitions
Added a dedicated tag configuration UI on the gateway for FINS device connections.
Nightly Changelog: 8.0.11-b20200316
Ignition Platform
15382: Allow SQLite as database connection option
Ignition gateways can now create database connections to SQLite databases.
