Nightly Changelog: 8.1.49-SNAPSHOT-b20250703
Perspective
Perspective
IGN-11976: Update pdfmake/amcharts to version that updates es5-ext to fix CVE
Resolved CVE-2024-27088
Nightly Changelog: 8.1.49-SNAPSHOT-b20250710
IGN-13338: Store and Forward: Tags with the same name and path are incorrectly treated as duplicates when storing Tag History
Fixed an issue where a data point would be lost if two points shared the same timestamp and same tag path but differed in tag provider.
Nightly Changelog: 8.1.49-SNAPSHOT-b20250711
IGN-10171: The Web browser component's initialize extension function repeatedly calls the Initialization function when trying to modify property values.
Fixed an issue where setting the starting URL or starting HTML in the Web Browser component’s initialize function caused infinite loops and crashes.
Nightly Changelog: 8.1.49-SNAPSHOT-b20250714
IGN-11287: macOS Sequoia: local network permission
Mac os Installs now default the launch daemon to run as root to ensure local network access, meaning the Gateway runs as the root user as well to ensure proper access to the local network.
IGN-12583: Date Picker selectable date graphic does not match minDate and maxDate
Fixed date picker sometimes selecting day prior because timezone information wasn't initialized early enough.
IGN-9286: Table: Configuring the props.column.sort property does not immediately update the table column values in the Designer
Table now reacts to column sort property.
IGN-12879: Gauge needle frequently gets stuck at 0
Fixed gauge needle sometimes stuck at zero on load.
Nightly Changelog: 8.1.51-SNAPSHOT-b20250806
IGN-13292: Quick Start Translation Manager Typo
Fixed a typo in the 'Quick Start' project's embedded translations.
IGN-12735: Skip Button Click for autologin using IdPs on Vision Clients
Added automatic redirect to IdP login page for Vision clients.
Nightly Changelog: 8.1.51-SNAPSHOT-b20250916
IGN-5724: In Perspective the XY chart's connect property does not function as expected with empty/null data points
XY Chart will no longer display values of empty or null as 0 and such values will be correctly skipped when the connect prop is false.
Nightly Changelog: 8.1.51-SNAPSHOT-b20250923
IGN-13755: Replace or Update es5sham es6-promise due to CVE
Removed JS library references (ES6 Promise and ES5 shim and sham) due to security vulnerabilities. These libraries were in place to handle legacy versions of IE (version 11 support was dropped in 2022).
