Nightly 8.3 Changelogs - 2026 and beyond
Nightly Changelog: 8.3.11*-b20261001
Alarming
Alarm Status
IGN-17795: Active Alarms Don't Clear Using Percent Deadband Mode
Fixed an issue where an alarm, with its Deadband Mode set to Percent, would never clear once active.
Gateway Network
Gateway Network
IGN-17569: Tuples returned from a message handler do not decode properly over the Gateway Network
Fixed a Gateway Network serialization bug that caused values inside tuples returned by message handlers to decode improperly.
Web UI
Web UI
IGN-16579: Terminate Session menu item shall be disabled for Read users
The Terminate Session action on the Perspective Sessions page is now disabled for users without Gateway Write permission.
Nightly Changelog: 8.3.11*-b20261002
Alarming
Alarm Status
**IGN-16742: Alarm Associated Data property is getting cleared unexpectedly when another property is modified **
Fixed an issue where modifying an Alarm Associated Data property in the edit panel could unexpectedly clear another existing Associated Data property.
Comms
Drivers
IGN-17910: Modbus RTU config migration use baudRate instead of bitRate
Fixed an issue in the Modbus RTU driver where the Bit Rate setting was not carried over when upgrading from Ignition 8.1 to 8.3.
Web UI
Web UI
IGN-16563: Device Roles & Permissions drawer submit button lacks loading/disabled state during update
The Save Changes button in the Device Roles & Permissions drawer is now disabled and shows a loading indicator while changes are being saved.
Nightly Changelog: 8.3.11*-b20261005
Data & Logic
SQL Bridge
IGN-16896: Stored Procedure Transaction Groups fail to execute for PostgreSQL REAL data types
Fixed an issue where a Stored Procedure Transaction Group failed to execute when passing a Float4 (single-precision) value to a PostgreSQL stored procedure with a REAL parameter.
Tags
Tags & UDTs
IGN-18024: Failover from Master -> Backup -> Master with changing tags can cause Signature mismatches
Fixed an issue where syncing Tag configurations between a redundant gateway pair could prevent saving tag configurations on the active gateway.
Nightly Changelog: 8.3.11*-b20261006
Tags
Tags & UDTs
IGN-18085: Security Info Box in Tag Editor Shows Incorrect Page Route
Fixed an issue where the info box in the Security section within the Tag Editor showed the incorrect 8.1 page route.
Nightly Changelog: 8.3.11*-b20261007
Web UI
Web UI
IGN-14118: Change 'Scan File System' Button Text
The generic "Scan File System" button now reads "Scan Project Files" on the Projects page and "Scan Config Files" on the Modes page, and the scan dialog's header and button text match.
IGN-11303: Incorrect Toast title casing on the Project page
Gateway web UI toast titles now use sentence case to match the designs (for example, "Project created" and "Scan complete" instead of "Project Created" and "Scan Complete").
Security
Identity Providers
IGN-18143: IdP security level rules under Authenticated are never granted when the IdP's config lists another root-level rule first
Fixed an issue where an Identity Provider granted none of its rule-based security levels under Authenticated if a rule on another top-level security level was configured first. To check if an IdP is affected, run its Test Login and see whether those levels are missing. After upgrading, they are granted as configured, so review those rules before upgrading.
Nightly Changelog: 8.3.11*-b20261008
Perspective
Perspective
IGN-6331: Video Player: Seek property only allows for seeking into the future
Fixed an issue where the video player would only adjust to a seek value ahead of the current elapsed time of the video and not before the current elapsed time.
Comms
Drivers
IGN-18185: Siemens Enhanced driver logs symbol-unavailable reads at WARN instead of DEBUG
Fixed an issue in the Siemens Enhanced driver where symbolic read failures caused by unavailable symbol info were logged at WARN instead of DEBUG.
Nightly Changelog: 8.3.11*-b20261015
Web UI
Web UI
IGN-16778: Improve automation locators on the OAuth page
Added unique element IDs to the test modals, Verify Authorization button, Timestamp metric cards, and inline tables on the OAuth2 Clients page to support browser automation.
IGN-16840: Edge Remote Notification Profile on 8.3 has unused 'Notification Profile' field
Fixed an issue where the Edge Remote Notification Profile could not be saved without entering a value in the unused Notification Profile field.
Nightly Changelog: 8.3.11*-b20261016
Web UI
Web UI
IGN-16883: Language dropdown when creating a user in the Internal user source has no type-ahead/search — must scroll the entire locale list
Fixed an issue where typing in the Language dropdown when adding a user to an Internal user source did not jump to a matching language.
Nightly Changelog: 8.3.11*-b20261019
Security
Security
IGN-18200: Clearing a child level's rule in the IdP Security Level Rules editor also clears the parent level's rule
Fixed an issue in the Identity Provider Security Level Rules editor where clearing one security level's rule could also remove its parent level's rule, drop its child levels' rules on save, or make a parent's rule look cleared when it was still saved. Clearing a rule now affects only that level. If you edited security level rules on an earlier 8.3 version, review each Identity Provider's rules to confirm they are what you intended.
User Sources
IGN-18140: AD User Source Greyed Out After 8.1 to 8.3.9 Upgrade/Restore If 'Role Name Attribute' Is Left Blank in 8.1
Fixed issue where 8.1 to 8.3 migration failed on an AD user source when RoleNameAttribute was blank in 8.1, which left the user source unusable.
Cloud Connectors
Event Streams
IGN-18091: Event Streams HTTP handler X icon shows unresolved localization key as tooltip
Fixed an issue where the required-field validation icon on Event Streams handler expression fields showed a raw localization key in its tooltip.
Web UI
Web UI
IGN-12303: IDP - Add User Modal - Button Sizing
Fixed an issue with button sizing and field spacing in the Identity Provider Add User and Edit User modals.
Platform Core
Projects
IGN-18127: Gateway Projects page doesn't show new projects after Scan File System
Fixed an issue where new projects found by a file system scan did not appear on the Gateway Projects page until the page was refreshed.
Nightly Changelog: 8.3.11*-b20261021
Security
User Sources
IGN-18429: AD migration writes user source settings to properties that do not exist
Fixed an issue where upgrading from 8.1 did not keep the Full Name Attribute on AD/Internal Hybrid user sources or the SSO settings on Active Directory user sources. Gateways already upgraded to 8.3 may need these settings re-entered.
Nightly Changelog: 8.3.11*-b20261022
Tags
Tags & UDTs
IGN-18413: Added Members to UDT Definition are not Persisted to Disk Through Import
Fixed an issue prevent UDT members from persisting to disk
Web UI
Web UI
IGN-14988: Polish: Leased 8-Character License Key Activation Form
Fixed license activation failing with a "Missing 'activationToken' property" error when the license key was entered in lowercase or with leading or trailing spaces.
