Numeric Entry Field labeled border
You can get "flex" action if you set a coordinate view props.mode : percent.
CoordNumericWithBorder
To reproduce paste this view into your Project Browser.
coordNumericEntryWidget
  "custom": {},
  "params": {
    "caption": "Caption",
    "value": 3.1416
  "propConfig": {
    "params.caption": {
      "paramDirection": "input",
      "persistent": true
    "params.value": {
      "paramDirection": "inout",
      "persistent": true
  "props": {
    "defaultSize": {
      "height": 83,
      "width": 465
  "root": {
    "children": [
        "meta": {
          "name": "lblBorder"
        "position": {
          "width": 1
        "propConfig": {
          "position.height": {
            "binding": {
              "config": {
                "expression": "({view.props.defaultSize.height} - {this.props.style.marginTop})\r\n/ {view.props.defaultSize.height}"
              "type": "expr"
        "props": {
          "style": {
            "borderBottomLeftRadius": 10,
            "borderBottomRightRadius": 10,
            "borderColor": "#888282",
            "borderStyle": "solid",
            "borderTopLeftRadius": 10,
            "borderTopRightRadius": 10,
            "borderWidth": 1,
            "marginTop": 10
        "type": "ia.display.label"
        "meta": {
          "name": "txtNumericEntry"
        "position": {
          "height": 0.3556,
          "width": 1,
          "y": 0.4444
        "propConfig": {
          "props.value": {
            "binding": {
              "config": {
                "bidirectional": true,
                "path": "view.params.value"
              "type": "property"
        "props": {
          "style": {
            "marginLeft": 15,
            "marginRight": 15
        "type": "ia.input.numeric-entry-field"
        "children": [
            "meta": {
              "name": "lblCaption"
            "position": {
              "shrink": 0
            "propConfig": {
              "props.text": {
                "binding": {
                  "config": {
                    "path": "view.params.caption"
                  "type": "property"
            "props": {
              "style": {
                "backgroundColor": "#f7f7f7",
                "paddingLeft": 5,
                "paddingRight": 5
        "meta": {
          "name": "FlexContainer"
        "position": {
          "height": 1,
          "width": 1
        "props": {
          "alignContent": "flex-start",
          "alignItems": "flex-start",
          "style": {
            "paddingLeft": 15
        "type": "ia.container.flex"
    "meta": {
      "name": "root"
    "props": {
      "mode": "percent"
    "type": "ia.container.coord"
The main trick in this is to convert coordinates to percentages. I've done this using an integer number of pixels divided by the view width or height. e.g.
20 / {view.props.defaultSize.width}
The caption is a view parameter. The value is also a parameter but set as bidirectional through the various views.
Have fun.
