Сonverting values
Good day!
We came another question.
Our function in the element is invoked as follows
runScript(concat("app.DMK.convert(",toStr({Power Supply /DMK32 First Power input/Active power of phase L1}),")"))
We need to return the element itself Decrease the number of such in 1000, as it can be done without making addenda in the function.
can be passed to the function parameter More like so
def convert(inputValue, inputParam): if inputParam == 1: outputValue=int(str((hex(inputValue))[:-4]),16)/1000 else outputValue=int(str((hex(inputValue))[:-4]),16) return outputValue
But unfortunately, this design does not work
Another problem is the value of type int, because if for example 21300 / 1000 = 21.3, and the function returns 21
The problem is solved!
Function
def convert(inputValue,inputParam): return float(int(str((hex(inputValue))[:-4]),16)) / inputParam
The function call
runScript(concat("app.DMK.convert(",toStr({inputValue}),",1000",")"))
[Fix]
Function
def convert(inputValue,inputParam): return float(inputValue >> 16) / inputParam
The function call
runScript(concat("app.DMK.convert(",toStr({inputValue}), ",", toStr(1000),")"))
After you define the function as described in the previous post, periodically get an error:
[code]Exception: Error executing expression binding on
First power input.Root Container.Power.Rated power .Rated power of phase L1.value
caused by ExpressionException: Error parsing script for runScript() expression: Traceback (innermost last):
(no code object) at line 0
OverflowError: integer literal too large
caused by Traceback (innermost last):
Ignition v7.3.1 (b496)
Java: Sun Microsystems Inc. 1.6.0_24[/code]
In what may be the problem?
Sorry, I was on vacation yesterday. Let me look over what you’ve got, and I’ll post something up for you. :slight_smile:
I modified the function to change the order of magnitude as a function of the transmitted Parameters. as follows
The function call
The converted value is divided by 1000
This method works, but occasionally an error
Try:
def convert(inputValue,inputParam): return float(1L*inputValue >> 16) / inputParam
I think that occasionally it attempting to use the inputValue as an integer when it should be using it as a long integer. Multiplying by 1L should coerce the input to a long.
Nice use of a bit shift, by the way! :smiley:
Unfortunately did not help
All right, how about the previous one?
Or if looks too complex-- Not too complex for you to understand, just if it looks too busy:
def convert(inputValue,inputParam): return int(str((hex(inputValue))[:-4]),16) / float(inputParam)
Also, do you have an example of what input value does not work?
Managed to get rid of the error.
currently function looks like:
def convert(inputValue,inputParam): return float(long(inputValue) >> 16) /inputParam
Error stopped appearing after SalTag type has been changed to Float.
P.S.
Could you show a small example of how to use the script in the transation group to save data base the converted values.
:slight_smile:
Sure! I have a meeting to run off to, but I’ll put one together afterwords.
Here you go.
