Oracle JDBC Driver Issue Fix
Go to the install directory on the gateway and find the user-lib/jdbc/ folder, remove the Oracle driver you added, and restart the gateway. And then upgrade your gateway; if you go to Ignition 8.1.33 or later you can use the ODBC17 jar just fine.
