Given @pturmel's feedback, I think I'll update my library to a single function:
def unQualify(qvObject):
if qvObject is None:
return None
if isinstance(qvObject, list):
return [val.value for val in qvObject]
elif isinstance(qvObject, dict):
return dict([(k, qv.value) for (k, qv) in qvObject.items()])
Not a bad plan, but that implementation will not handle java implementations of lists and dictionaries. Consider checking for the items method (via hasattr()) to trigger dictionary handling, then iterating over the rest. (Duck typing is more reliable than isinstance().
Thanks, that explains why it wasn't working. This does:
return None
if hasattr(qvObject, 'items'):
else:
You don't need the brackets, you can use a generator here. And if the java dicts implement .iteritems (I don't remember if they do), you could also use that, so no list is produced while you extract the value from the qv.
This does appear to work:
def extractQualifiedValues(qvObject):
return None
if hasattr(qvObject, 'iteritems'):
return dict((k, qv.value) for (k, qv) in qvObject.iteritems())
else:
I am interested in making it as efficient as possible, since that's the main reason for using runScript. Maybe one day I'll finally start using @pturmel's Toolkit...
Please don't call it unQualify(), as it is not a 1:1 replacement for mine. My toolkit recursively handles nested lists and dictionaries, with cycle detection to avoid infinite loops.
