In the indirect tag binding, use:
{1}/Parameters/desc
And in the References:
| Reference | Property |
| 1 | {view.params.deviceTagPath} |
Where view.params.deviceTagPath is passed in as:
"[OTSE_MFG]Reel/Primary Area/_71_5048_SM611_FS1_SpoolReleaseLocked"
In your previous posts, by trying to bind to the tag with path "[OTSE_MFG]Reel/Primary Area/_71_5048_SM611_FS1_SpoolReleaseLocked/parameters", this isn't a valid tag path as you're missing the item you're trying to read.
Note: you can also use the tag path:
{1}/Parameters.desc
Although I prefer to keep the "/" instead of the "." for the rare instances where I choose not to use a udt instance for some types, but still use the same UDT definition's folder structure. Likely nothing important for you to worry about
