Passing column name as a variable to a named query
This is the named query:
INSERT INTO a_stats.dock_door_induct_counts ({param1}) VALUES (:param2);
What happens if you drag the parameter into your query?
It doesnt look like A_Stats is defined anywhere. If this is the name of your project, then it should be within apostrophes or quotes
Wait. The problem is at the logger. Try:
logger.info (str(params['param1']))
Or better yet, to see the entire dictionary:
logger.info (str(params))
For future reference, the traceback tells you what line the script fails at.
Ah Ha!!! ‘A_Stats’ worked. It is a wonderful day in the neighborhood.
Thank you all!!
