[BUG-16846] Perspective designer issues after losing connection
Ignition 8.0.14
I usually get the following error when I have the designer open on a Perspective view and I temporarily lose connection to the gateway. Usually the loss of connection is due to me connecting to a client’s VPN. One the connection comes back I get the following error. I am then unable to save / run bindings correctly.
07:18:53.582 [AWT-EventQueue-0] WARN Perspective.SessionProps - Unable to obtain session props for save.
java.util.concurrent.ExecutionException: java.lang.Exception: Unable to get the view config: View config is undefined.
	at java.base/java.util.concurrent.CompletableFuture.reportGet(Unknown Source)
	at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
	at com.inductiveautomation.perspective.designer.workspace.pageconfig.SessionPropsAdapter.commit(SessionPropsAdapter.java:134)
	at com.inductiveautomation.perspective.designer.workspace.pageconfig.WorkspaceRootConfig.commit(WorkspaceRootConfig.java:28)
	at com.inductiveautomation.perspective.designer.workspace.ViewWorkspace.notifyProjectSaveStart(ViewWorkspace.java:292)
	at com.inductiveautomation.perspective.designer.DesignerHook.notifyProjectSaveStart(DesignerHook.java:439)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner.commitAll(IgnitionDesigner.java:1573)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler.handleUpdate(IgnitionDesigner.java:2780)
	at com.inductiveautomation.ignition.designer.IgnitionDesigner$Handler$8.actionPerformed(IgnitionDesigner.java:2349)
	at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
	at com.jidesoft.plaf.basic.BasicJideButtonListener.mouseReleased(Unknown Source)
	at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
Caused by: java.lang.Exception: Unable to get the view config: View config is undefined.
	at com.inductiveautomation.perspective.designer.workspace.JavaJsBridge.onSaveError(JavaJsBridge.java:112)
	at com.teamdev.jxbrowser.chromium.JSContext.a(SourceFile:1640)
	at com.teamdev.jxbrowser.chromium.JSContext$a.onMessageReceived(SourceFile:713)
	at com.teamdev.jxbrowser.chromium.internal.ipc.q.a(SourceFile:1085)
	at com.teamdev.jxbrowser.chromium.internal.ipc.r.run(SourceFile:69)
	at com.teamdev.jxbrowser.chromium.internal.t.run(SourceFile:79)
07:18:53.582 [Browser Events Thread] INFO Perspective.SessionProps - store.DesignerViewInstance: Attempted to collect View Configuration for save, but root view not found!
Okay, Jae. We are working on it. Thanks for the report.
I just received the same error for a similar situation.
	at com.inductiveautomation.perspective.designer.workspace.JavaJsBridge.onSaveError(JavaJsBridge.java:118)
	at com.teamdev.jxbrowser.frame.internal.FrameImpl.invokeObjectMethod(FrameImpl.java:574)
	at com.teamdev.jxbrowser.frame.internal.FrameImpl.processCallback(FrameImpl.java:166)
	at com.teamdev.jxbrowser.internal.rpc.stream.CallbackStream.process(CallbackStream.java:178)
	at com.teamdev.jxbrowser.internal.rpc.stream.Stream$StreamObserver.lambda$onNext$0(Stream.java:162)
	at com.teamdev.jxbrowser.internal.BrowserThread$TaskRunner.processTasks(BrowserThread.java:137)
18:40:20.307 [Browser Thread: 49703] ERROR Perspective.Designer.Workspace - level: LEVEL_ERROR
message: "store.DesignerViewInstance: Attempted to collect View Configuration for save, but root view not found!"
Is there a fix for this?
I’m on 8.1.1 and after losing connection and getting it back, every time I save this error pops up and it seems like things start messing up, like parameters gone, custom properties, etc.
