Perspective: Display tags value in table format
How do I programmatically add Column to Table.Column Property? as If I were to click the add button manually?
Edit: The below worked. Thanks.
Probably, should I manually right-click copy the sample column object, and paste the JSON string onto variable in my script and use that as template?
I have multiple tags for Read and Write. I want to use table and value column need to edit the tag values. And Value column view may change Text box and Check box based on Tag. You have any script kindly provide me
