The generally recommended approach is to retrieve your data at the top level of the binding (via query, HTTP binding, whatever) and then use a script transform - you can loop through the result rows and add a style key as appropriate. Take a look at this thread for some inspiration; it's a bit more complicated than you might need (supporting per-column cell styling) but should be an inspiration:
