Perspective Line Breaks in text label/markdown
Try this:
if tag_check_neagtive:
    negative_message = 'This chart is unavailable for string type data. Please unselect the tags listed below from the Tag Tree Browser.'
    negative_message += '<br/>'.join([r'\[{}\]{}'.format(tag.source,tag.toStringPartial()) for tag in tag_check_neagtive])
    system.perspective.openPopup("Warning", "test",
                                 {"message": negative_message}, "Error",
                                 modal=True, showCloseIcon=True, draggable=False, resizable=False)
Or you can replace [ with HTML entity &#91; and ] with &#93;.
By the way, I think you have spelt "negative" incorrectly in "tag_check_neagtive:". You might want to fix that.
This will also work, I've just always found that very cryptic.
I noticed the typo as well.
getting some error
code is not passing this line
Hard to help if I don't know what the error is.
com.inductiveautomation.ignition.common.script.JythonExecException
  File "<function:onMessageReceived>", line 87, in onMessageReceived
AttributeError: 'unicode' object has no attribute 'source'
	caused by org.python.core.PyException
Okay, so the list, is really a list of strings, not TagPath objects.
    negative_message += '<br/>'.join([r'\[{}\]{}'.format(tag[1:tag.find(']')],tag[tag.find(']') + 1:]) for tag in tag_check_neagtive])
Its working there is syntax error i have corrected it
negative_message += '<br/>'.join([r'\[{}\]{}'.format(tag[1:tag.find(']')], tag[tag.find(']') + 1:]) for tag in tag_matched])
As an alternative, you can also use re.split to split by multiple delimiters, instead of using find:
import re
a = '[default]tag/path'
re.split('\[|\]', a)[1:] # split by "[" or "]", discarding the first find
>> ['default', 'tag/path']
