[Perspective] onFileReceived - CSV File UTF-8 vs ASCII
I took a look at this for you, and from what I can discern (in attempting to reproduce a similar file with Excel), Excel is producing a UTF-8 with BOM (byte order mark). Thankfully, you should be able to detect this and fairly easily remove it (below is your code above with modifications):
	import csv
	from StringIO import StringIO
	logger = system.util.getLogger("import_recipe_parameters")
	file_bytes = event.file.getBytes()
	# Check to see if this is UTF-8 with BOM
	if bytearray.fromhex("ef bb bf") == bytearray(file_bytes[0:3]):
		# Strip first three bytes
		file_bytes = file_bytes[3:]
	try:
		# Read in from file_bytes.tostring() now...
		reader = csv.reader(StringIO(file_bytes.tostring()), delimiter=";")
		header = reader.next()
		converted_data = [[column.replace(',', '.') for column in row] for row in reader]
		self.view.custom.table.data = system.dataset.toDataSet(header, converted_data)
	except:
		import traceback
		logger.error("Error: %s" % traceback.format_exc())
