I ran into a problem using a slider to select a time of day for a chart query binding. Wanging the slider caused frequent chart binding refreshes which seemed to cause a “too many connections” problem with MySQL and the XY chart was taking quite a while to catch up.
I’ve been trying to come up with a way of delaying the refresh until the onMouseUp event but that doesn’t work if the mouse is released outside the component. I added the onMouseOut event which improves the situation but there are still a few escapes. I created this little demo where the blue bar follows the slider but the green bar should only update when the adjustment is complete.
Note that moving the mouse out diagonally leaves the green out of sync with the blue.
Drop this into a Perspective coordinate view root container to reproduce.
"type": "ia.input.slider",
"version": 0,
"props": {
"value": 7,
"max": 10
"meta": {
"name": "Slider"
"position": {
"x": 37,
"y": 106,
"height": 32,
"width": 192
"custom": {
"mouseEventTime": {
"ts",
192,
1653630967417
"$ts": 1653630967417
"propConfig": {
"custom.labelClearTimeDelay": {
"binding": {
"type": "expr",
"config": {
"expression": "(now(100) - {this.custom.mouseEventTime}) > 1000"
"events": {
"dom": {
"onMouseLeave": {
"type": "script",
"scope": "G",
"config": {
"script": "\tself.custom.mouseEventTime = system.date.now()\n\tsystem.perspective.sendMessage(\"refreshStartTime\", payload = {\"startTime\": self.props.value}, scope = 'view')\n\tself.getSibling(\"lblMouseEvents\").props.text = \"onMouseLeave\"\n"
"onMouseUp": {
"type": "script",
"scope": "G",
"config": {
"script": "\tself.custom.mouseEventTime = system.date.now()\n\tsystem.perspective.sendMessage(\"refreshStartTime\", payload = {\"startTime\": self.props.value}, scope = 'view')\n\tself.getSibling(\"lblMouseEvents\").props.text = \"onMouseUp\"\n\t"
"type": "ia.display.label",
"version": 0,
"props": {
"textStyle": {
"borderColor": "--neutral-20",
"borderStyle": "solid",
"borderWidth": 1,
"textAlign": "center"
"meta": {
"name": "lblMouseEventsDisplay"
"position": {
"x": 40,
"y": 154,
"height": 32,
"width": 191
"custom": {},
"propConfig": {
"props.text": {
"binding": {
"type": "expr",
"config": {
"expression": "if({../Slider.custom.labelClearTimeDelay}, \" - \", {../lblMouseEvents.props.text})"
"type": "ia.display.progress",
"version": 0,
"props": {
"max": 10,
"valueDisplay": {
"enabled": true
"meta": {
"name": "progLive"
"position": {
"x": 37,
"y": 70,
"height": 20,
"width": 200
"custom": {
"lastAdjustTime": "value"
"propConfig": {
"props.value": {
"binding": {
"type": "property",
"config": {
"path": "../Slider.props.value"
"version": 0,
"props": {
"max": 10,
"value": 7,
"bar": {
"color": "#12A30D"
"valueDisplay": {
"enabled": true
"meta": {
"name": "progDelayed"
"position": {
"x": 37,
"y": 35,
"height": 20,
"width": 200
"custom": {},
"scripts": {
"customMethods": [],
"messageHandlers": [
"messageType": "refreshStartTime",
"script": "\tself.props.value = payload[\"startTime\"]",
"sessionScope": false,
"pageScope": false,
"viewScope": true
"extensionFunctions": null
"version": 0,
"props": {
"text": "onMouseLeave",
"textStyle": {
"meta": {
"name": "lblMouseEvents"
"position": {
"x": 41,
"y": 192,
"height": 32,
"width": 191
"custom": {}
Has anyone got any ideas how to make this more robust?
