Perspective PDF Viewer without WebDev
Perfect. GUID should be obscure enough for my case. Thanks Phil.
Thank you for this, it is an incredibly easy way to display a few documents. I just put the PDFs that I needed in that directory using file explorer. I personally found the PDF viewer to be unhelpful for schematics because you cannot zoom, so I simply used the link object to a new tab.
Using the webserver's main folder is explicitly unsupported and only works "accidentally". It has some pathological behaviors in regards to file handle leakage and inability to delete files. It is only safe to use for permanent/static content. Nothing dynamic.
Thank you for this clarification. We are using it for non-essential, static documentation, but I will keep this in mind.
