Perspective Pipes Z-Height
I have a method it may not be the best, but it allows for you to change the z order.
What you can do is place all of the pipes inside of a coordinate container (I call this the CoordinateContainer_PIPES) Then you are able to move that specific coordinate container order either in front or behind other objects here is an example of the view:
Notice how tank 2 is behind the pipes while tank 1 is laying on top of the pipes.
To copy this view copy all of the JSON. Create a new view within Ignition then press SHIFT+Right click on the new view then paste the JSON.
  "custom": {},
  "params": {},
  "props": {},
  "root": {
    "children": [
        "meta": {
          "name": "Polyethylene tank 2"
        "position": {
          "height": 369,
          "width": 190,
          "x": 85
        "props": {
          "elements": [
              "elements": [
                  "d": "M0,15.653h77.363V112.5H0V15.653",
                  "fill": {
                    "paint": {
                      "gradientUnits": "userSpaceOnUse",
                      "stops": [
                          "offset": "0",
                          "style": {
                            "stopColor": "#383838"
                          "offset": "0.47",
                          "style": {
                            "stopColor": "#ECECEC"
                          "offset": "0.55",
                          "style": {
                            "stopColor": "#D9D9D9"
                          "offset": "0.7",
                          "style": {
                            "stopColor": "#A8A8A8"
                          "offset": "0.91",
                          "style": {
                            "stopColor": "#5A5A5A"
                          "offset": "1",
                          "style": {
                      "type": "linear",
                      "x1": "2.441406e-004",
                      "x2": "77.3635",
                      "y1": "64.0762",
                      "y2": "64.0762"
                  "name": "path",
                  "type": "path"
                  "d": "M9.572,15.653h1.239v4.73H9.572V15.653z",
                  "fill": {
                    "paint": "#707070"
                  "name": "path",
                  "type": "path"
                  "d": "M15.653,15.653h1.127v4.73h-1.127V15.653z",
                  "fill": {
                    "paint": "#707070"
                  "name": "path",
                  "type": "path"
                  "d": "M60.472,15.653h1.127v4.73h-1.127V15.653z",
                  "fill": {
                    "paint": "#707070"
                  "name": "path",
                  "type": "path"
                  "d": "M66.553,15.653h1.126v4.73h-1.126V15.653z",
                  "fill": {
                    "paint": "#707070"
                  "name": "path",
                  "type": "path"
              "name": "Group_TankBody",
              "type": "group"
              "elements": [
                  "d": "M4.617,102.814h7.432v9.686H4.617V102.814z",
                  "fill": {
                    "paint": "#CCCCCC"
                  "name": "path",
                  "type": "path"
                  "d": "M4.617,102.814h7.432l-4.842,2.365l-2.59,7.32V102.814z",
                  "fill": {
                    "paint": "#AFAFAF"
                  "name": "path",
                  "type": "path"
                  "d": "M65.202,102.814h7.207v9.686h-7.207V102.814z",
                  "fill": {
                    "paint": "#CCCCCC"
                  "name": "path",
                  "type": "path"
                  "d": "M65.202,102.814h7.207l-4.73,2.365l-2.477,7.32V102.814z",
                  "fill": {
                    "paint": "#AFAFAF"
                  "name": "path",
                  "type": "path"
              "name": "Group_",
              "type": "group"
              "elements": [
                  "d": "M6.081,15.653v-1.238c0,0-1.315-7.665,28.266-8.333c2.139-0.048,6.42-0.099,8.558,0   c28.861,1.335,28.379,8.333,28.379,8.333v1.238H6.081",
                  "fill": {
                    "paint": {
                      "stops": [
                          "offset": "0",
                          "style": {
                          "offset": "0.04",
                          "style": {
                            "stopColor": "#4B4B4B"
                          "offset": "0.15",
                          "style": {
                            "stopColor": "#848484"
                          "offset": "0.26",
                          "style": {
                            "stopColor": "#B1B1B1"
                          "offset": "0.36",
                          "style": {
                            "stopColor": "#D1D1D1"
                          "offset": "0.44",
                          "style": {
                            "stopColor": "#E5E5E5"
                          "offset": "0.49",
                          "style": {
                          "offset": "0.55",
                          "style": {
                          "offset": "0.63",
                          "style": {
                            "stopColor": "#D4D4D4"
                          "offset": "0.72",
                          "style": {
                            "stopColor": "#B6B6B6"
                          "offset": "0.83",
                          "style": {
                            "stopColor": "#8E8E8E"
                          "offset": "0.94",
                          "style": {
                          "offset": "1",
                          "style": {
                      "type": "linear",
                      "x1": "6.0725",
                      "x2": "71.2844",
                      "y1": "10.8389",
                      "y2": "10.8389"
                  "name": "path",
                  "type": "path"
              "name": "Group_T",
              "type": "group"
              "elements": [
                  "d": "M37.499,0.243h2.253l3.604,1.267h-9.685L37.499,0.243z",
                  "fill": {
                    "paint": "#4C4C4C"
                  "name": "path",
                  "type": "path"
                  "d": "M31.418,2.892h14.415V1.154H31.418V2.892z",
                  "fill": {
                    "paint": {
                      "stops": [
                          "offset": "0",
                          "style": {
                          "offset": "0.47",
                          "style": {
                          "offset": "0.55",
                          "style": {
                          "offset": "0.7",
                          "style": {
                          "offset": "0.91",
                          "style": {
                          "offset": "1",
                          "style": {
                      "type": "linear",
                      "x1": "31.4182",
                      "x2": "45.8333",
                      "y1": "2.0234",
                      "y2": "2.0234"
                  "name": "path",
                  "type": "path"
                  "d": "M28.941,2.707H48.31v1.407H28.941V2.707z",
                  "fill": {
                    "paint": {
                      "stops": [
                          "offset": "0",
                          "style": {
                          "offset": "0.47",
                          "style": {
                          "offset": "0.55",
                          "style": {
                          "offset": "0.7",
                          "style": {
                          "offset": "0.91",
                          "style": {
                          "offset": "1",
                          "style": {
                      "type": "linear",
                      "x1": "28.9407",
                      "x2": "48.3098",
                      "y1": "3.4106",
                      "y2": "3.4106"
                  "name": "path",
                  "type": "path"
                  "d": "M27.815,3.604h21.622l1.351,12.049H26.464L27.815,3.604z",
                  "fill": {
                    "paint": {
                      "stops": [
                          "offset": "0",
                          "style": {
                          "offset": "0.47",
                          "style": {
                          "offset": "0.55",
                          "style": {
                          "offset": "0.7",
                          "style": {
                          "offset": "0.91",
                          "style": {
                          "offset": "1",
                          "style": {
                      "type": "linear",
                      "x1": "26.4641",
                      "x2": "50.7874",
                      "y1": "9.6289",
                      "y2": "9.6289"
                  "name": "path",
                  "type": "path"
              "name": "Group_Top",
              "type": "group"
          "viewBox": "0 0 77.363 112.5"
        "type": "ia.shapes.svg"
        "meta": {
          "name": "CoordinateContainer_PIPES"
        "position": {
          "height": "100%",
          "width": "100%"
        "props": {
          "pipes": [
              "appearance": "auto",
              "end": "none",
              "fill": "",
              "flanges": true,
              "lineVariant": "solid",
              "name": "pipe",
              "origin": {
                "connections": [
                    "connections": [
                        "connections": [
                            "connections": [
                                "connections": [
                                    "connections": [
                                        "x": 380,
                                        "y": 229
                                    "x": 132,
                                    "y": 229
                                "x": 132,
                                "y": 123
                            "x": 217,
                            "y": 123
                        "x": 217,
                        "y": 283
                    "x": 42,
                    "y": 283
                "x": 42,
                "y": 42
              "start": "none",
              "stroke": "",
              "visible": true,
              "width": 10
        "type": "ia.container.coord"
        "meta": {
          "name": "Polyethylene tank 1"
        "position": {
          "height": 109,
          "width": 44,
          "x": 301,
          "y": 169
        "props": {
          "elements": [
              "elements": [
                  "fill": {
                    "paint": {
                      "stops": [
                          "offset": "0",
                          "style": {
                          "offset": "0.47",
                          "style": {
                          "offset": "0.55",
                          "style": {
                          "offset": "0.7",
                          "style": {
                          "offset": "0.91",
                          "style": {
                          "offset": "1",
                          "style": {
                      "type": "linear",
                      "x2": "77.3635",
                      "y1": "64.0762",
                      "y2": "64.0762"
                  "name": "path",
                  "type": "path"
                  "fill": {
                    "paint": "#707070"
                  "name": "path",
                  "type": "path"
                  "fill": {
                    "paint": "#707070"
                  "name": "path",
                  "type": "path"
                  "fill": {
                    "paint": "#707070"
                  "name": "path",
                  "type": "path"
                  "fill": {
                    "paint": "#707070"
                  "name": "path",
                  "type": "path"
              "type": "group"
              "elements": [
                  "fill": {
                    "paint": "#CCCCCC"
                  "name": "path",
                  "type": "path"
                  "fill": {
                    "paint": "#AFAFAF"
                  "name": "path",
                  "type": "path"
                  "fill": {
                    "paint": "#CCCCCC"
                  "name": "path",
                  "type": "path"
                  "fill": {
                    "paint": "#AFAFAF"
                  "name": "path",
                  "type": "path"
              "name": "Group_",
              "type": "group"
              "elements": [
                  "fill": {
                    "paint": {
                      "stops": [
                          "offset": "0",
                          "style": {
                          "offset": "0.04",
                          "style": {
                          "offset": "0.15",
                          "style": {
                          "offset": "0.26",
                          "style": {
                          "offset": "0.36",
                          "style": {
                          "offset": "0.44",
                          "style": {
                          "offset": "0.49",
                          "style": {
                          "offset": "0.55",
                          "style": {
                          "offset": "0.63",
                          "style": {
                          "offset": "0.72",
                          "style": {
                          "offset": "0.83",
                          "style": {
                          "offset": "0.94",
                          "style": {
                          "offset": "1",
                          "style": {
                      "type": "linear",
                      "x1": "6.0725",
                      "x2": "71.2844",
                      "y1": "10.8389",
                      "y2": "10.8389"
                  "name": "path",
                  "type": "path"
              "name": "Group_T",
              "type": "group"
              "elements": [
                  "fill": {
                    "paint": "#4C4C4C"
                  "name": "path",
                  "type": "path"
                  "fill": {
                    "paint": {
                      "stops": [
                          "offset": "0",
                          "style": {
                          "offset": "0.47",
                          "style": {
                          "offset": "0.55",
                          "style": {
                          "offset": "0.7",
                          "style": {
                          "offset": "0.91",
                          "style": {
                          "offset": "1",
                          "style": {
                      "type": "linear",
                      "x1": "31.4182",
                      "x2": "45.8333",
                      "y1": "2.0234",
                      "y2": "2.0234"
                  "name": "path",
                  "type": "path"
                  "fill": {
                    "paint": {
                      "stops": [
                          "offset": "0",
                          "style": {
                          "offset": "0.47",
                          "style": {
                          "offset": "0.55",
                          "style": {
                          "offset": "0.7",
                          "style": {
                          "offset": "0.91",
                          "style": {
                          "offset": "1",
                          "style": {
                      "type": "linear",
                      "x1": "28.9407",
                      "x2": "48.3098",
                      "y1": "3.4106",
                      "y2": "3.4106"
                  "name": "path",
                  "type": "path"
                  "fill": {
                    "paint": {
                      "stops": [
                          "offset": "0",
                          "style": {
                          "offset": "0.47",
                          "style": {
                          "offset": "0.55",
                          "style": {
                          "offset": "0.7",
                          "style": {
                          "offset": "0.91",
                          "style": {
                          "offset": "1",
                          "style": {
                      "type": "linear",
                      "x1": "26.4641",
                      "x2": "50.7874",
                      "y1": "9.6289",
                      "y2": "9.6289"
                  "name": "path",
                  "type": "path"
              "type": "group"
    "meta": {
      "name": "root"
