The Setup
Ignition v8.1.27 (b2023042509)
Browsers tested: Firefox, Edge, Chrome
URL Params
I've created a table page autoplayer using a binding to a slider component, and I'm driving the number of rows on each page from a view parameter, which I specify as a url argument. This is a main view with no docked views.
Bindings
I have 3 bindings on the table.props.pager
properties.
options
is based on the initialOption
binding:
initialOption
is set to the url param rowsPerPage
activePage
is bound to the slider to control the page number:
The Problem
The issue is that when I first load the page, the pagination settings don't apply the way I'd expect them to. All the rows are rendering on the same page, creating a scrollbar I don't want. The pagination is just broken, as if the pager is disabled.
Refreshing the screen fixes this issue, and I get the right number of rows per page and the slider is able to drive the pagination automatically.
The Questions
I'd like to understand the update cycle for bindings like these to make this behavior make more sense to me.
- Why does this issue happen in the first place?
- Why does refreshing the tab fix this issue?
- Is this a bug?
- What can I do to avoid this issue and ensure the page loads the same every time?
