No, this bug hasn’t yet been fixed.
I have pulled every lever I can re: prioritization. If it’s an issue for you, contact support and have your rep add you to the internal ticket; that “bumps” its score relative to other tickets.
This trick worked for me, thanks @bao.nguyen
This did the trick for me as well. Thank you!!
How is the column configured in props? It looks like it's doing alpha sorting; if you want to do proper date sorting the column must be configured to render as date.
Rendering as date
Hmm. What version are you on? I located a known issue which was resolved in 8.1.10.
8.1.18
Okay, I'll try to see what might be going on.
Thanks for looking into it for me!
I wasn't able to replicate in 8.1.18.
Here, even though the 10:XX times appears out of order, it is due to a date difference:
Even while applying the same format as your example I have the sorting I would expect. The following screenshot was taken after removing and then re-applying sort to prevent any sort of cached sorting).
Is there any chance the values in your example have different dates?
No, that shouldn't matter, but you'll probably need to contact support for this one as I was unable to immediately replicate the issue.
Not sure if this bug has been resolved but I experienced this same behavior. I set the binding to persistent as suggested and it seems to have resolved the issue. Thanks for the solution @bao.nguyen!
Thank you!
Seems like this bug is still around. Thanks for the solution @bao.nguyen
