Perspective XY Chart xAxes tooltip text {dateX}
I thought of a way to get some other intervals per current interval.
It is like the solution Transistor said already with the batch labels.
Sort version is to add more datasets to the chart.
Create a lag, lead, preceding, or averaged column in the query.
Then reference that in the chart.
It would provide additional insight, while not being very dynamic though.
Probably comparing a moving average, weekly, or monthly would be the most applicable utility.
When I came across this old post, I felt compelled to append the idea.
Thank you!
To show the data of columns in the tooltip, when hovering mouse over the data in charts, you can use the column name in the tooltip text.
i.e: Adding tooltip configuration to each series.x.tooltip.text?
Example:
{name}:[bold]{valueY}[/]
Total Transfer:[bold]{Total_Transfer_Time}[/]
BT: [bold]{BrassTag}[/]
is there a sample for change the font size?
{label}: [bold]{valueY}[/]
try this
[font-size: 14px]Position: [bold font-size: 15px] {nameT} [/]
