Perspective - XYChart - Data from SQL - Auto requery periodically
If you’re able to put that logic into some expression using the dateFormat() or similar, those get outputted as java.util.Date as well and are also immediately usable for system.db.runPrepQuery. You would use a ? in your query where you need the date, no formatting on your part required. I know this isn’t the main point of your question but personally I hate having to manually handle and touch dates so I avoid it whenever possible.
