I don’t think HAVING will work, as it’s all in one row. This would have been an instance where a tall format would have worked better.
I would use a dataset custom property to hold the query, only coalescing nulls to zeroes (Craig, to answer your question, SUM will ignore nulls, but if all the values are null, so is the result ):
EDIT: Fixed COALESCE per conversation below.
SELECT
COALESCE(SUM(Crush_BF1),0) AS CrushBF1,
COALESCE(SUM(Crush_BF2),0) AS CrushBF1,
COALESCE(SUM(Crush_BF3),0) AS CrushBF1,
COALESCE(SUM(TTC2_BF1),0) AS TTC2BF1,
COALESCE(SUM(TTC3_BF1),0) AS TTC3BF1,
COALESCE(SUM(TTC3_BF2),0) AS TTC3BF2,
COALESCE(SUM(TTC3_BF3),0) AS TTC3BF3
FROM Backflow_Preventers
WHERE
t_stamp >= '{Root Container.TimeStart}' AND
t_stamp <= '{Root Container.TimeStop}'
Then use a propertyChange script to filter the results (my example uses ‘dataIn’ as the custom property):
if event.propertyName == 'dataIn':
datasetIn = event.source.dataIn
dataIn = system.dataset.toPyDataSet(datasetIn)
headersIn = system.dataset.getColumnHeaders(datasetIn)
headersOut =[]
dataOut = []
for row in dataIn:
rowOut = []
for header in headersIn:
print header, row[header]
if row[header] != 0:
headersOut.append(header)
rowOut.append(row[header])
dataOut.append(rowOut)
print headersOut, dataOut
event.source.data = system.dataset.toDataSet(headersOut, dataOut)
