Possible bug with system.util.audit in Edge
I'm running Ignition Edge 8.1 52 currently and run into the following problem. When calling system.util.audit in Vision without specifying the auditProfile, it will error out:
ValueError: No audit profile specified or found for the project
There is no place in designer for Edge that I could find to set this. There's a built-in profile named EdgeAuditProfile so I assumed it would just write to it automatically, but it doesn't. So if you manually specify the auditProfile as part of your call, then it works fine even though it's technically an optional argument. I found this the hard way by using a script I had used previously that just didn't work in Edge.
Can anyone else replicate it or is there some hidden setting I'm missing? I already have the Enable Auditing setting checked.
Edit: You can even just try running it in the script console and get the same error.
