Problem with tag Value Events - Value Change
In gateway scope, the database connection name argument to runQuery is required.
Your except: can inspect/print/log the actual exception information via python's sys and/or traceback modules, though you will need a separate except: clause to capture java errors. See this example:
Note that any uncaught errors or logging or printing from gateway scope show up in the gateway log, not in the designer's console or client console. Printing, in particular, only goes to the text-format wrapper log.
{ Have you gone through the lessons in IA's Inductive University ? That would cover many of the basic concepts of Ignition and Python that are tripping you up. }
