I think I figured everything out. Here is the full solution to run the designer from IntelliJ with my module code:
- Create a new run configuration in IntelliJ called DesignerStartupHook
- Click 'Modify Options' in the top right and enable the following:
- Set your classpath variable in the 'Build and Run' section of the run configuration to '-cp designer-launcher' (package that contains the pom.xml file previously discussed in this thread)
- Set the SDK to match that of your designer-launcher package and set the 'Main class' variable to
com.inductiveautomation.ignition.designer.DesignerStartupHook
- Put the following VM flags in the 'VM options' section. Note: your paths to various folders might be different:
--add-opens=java.base/java.lang=ALL-UNNAMED
--add-opens=java.base/java.util=ALL-UNNAMED
--add-opens=java.desktop/java.awt=ALL-UNNAMED
--add-opens=java.desktop/java.awt.event=ALL-UNNAMED
--add-opens=java.desktop/javax.swing=ALL-UNNAMED
--add-opens=java.desktop/javax.swing.tree=ALL-UNNAMED
--add-opens=java.desktop/javax.swing.plaf=ALL-UNNAMED
--add-opens=java.desktop/javax.swing.plaf.basic=ALL-UNNAMED
--add-opens=java.desktop/javax.swing.plaf.synth=ALL-UNNAMED
--add-exports=java.base/sun.security.action=ALL-UNNAMED
--add-exports=java.desktop/com.apple.eawt=ALL-UNNAMED
--add-exports=java.desktop/com.sun.awt=ALL-UNNAMED
--add-exports=java.desktop/com.sun.java.swing.plaf.windows=ALL-UNNAMED
--add-exports=java.desktop/sun.awt=ALL-UNNAMED
--add-exports=java.desktop/sun.awt.image=ALL-UNNAMED
--add-exports=java.desktop/sun.awt.shell=ALL-UNNAMED
--add-exports=java.desktop/sun.awt.windows=ALL-UNNAMED
--add-exports=java.desktop/sun.swing=ALL-UNNAMED
--add-exports=java.desktop/sun.swing.plaf.synth=ALL-UNNAMED
--add-exports=java.desktop/sun.swing.table=ALL-UNNAMED
--add-exports=java.desktop/sun.print=ALL-UNNAMED
-Dsr.gateway=localhost:8017
-Dautologin.username={your username}
-Dautologin.password={your password}
-Dignition.version=dev
-DlibPath="C:\Program Files\Inductive Automation\Ignition8.0.17\user-lib\pylib"
-Dpython.home="C:\\Program Files\\Inductive Automation\\Ignition8.0.17\\lib\\core\\common\\jython-2.7.1-ia5.jar"
- Go to File->Project Structure->Libraries. In the box on the right, click the '+' icon and navigate to the Ignition directory that contains all the jar files for the native Ignition modules. My jar directory path looks like this:
"C:\Program Files\Inductive Automation\Ignition8.0.17\data\jar-cache"
Inside of this directory are subdirectories of each module. Simply select all of these directories and add them to your project library.
- IMPORTANT In order to use the module code you currently have typed out in IntelliJ, you need also need to add your path to your fully built
.modl file into the project library. You also need to install your .modl file on the gateway at least once so the Designer can see and update your module from the GatewayInterface side.
- Upon adding your
.modl file to the project library, IntelliJ will ask you what to do with it, because it doesn't recognize the file structure. Select "Classes" and "Jar Directory" from the available options.
After doing all this, run your new configuration. Your Designer session should open with no errors if you added all jars to the project library correctly.
If you are reading this somewhere down the line and have questions or issues, feel free to DM me.
Update:
When using "-Dautologin.username" and "-Dautologin.password" on a remote gateway (I am attached to the network via VPN) the username and password aren't actually passed to the login. Is this simply because I am connecting to a remote gateway?
The autologin parameters only do anything if -Djavaws.ignition.debug=true is also set.
Is there an argument that I can use that allows me to launch a client from the programmatically-launched Designer? When I got to Tools>Launch Windowed I get the following error:
16:02:07.194 [DesignerExecEngine-1] ERROR Vision.DesignerModule -- Java process launch failed with error code 1:no other information is available
Probably not, but you can launch a Vision client using a very similar procedure as launching the designer.
Start from this set of runtime args (n.b. these will all be different in 8.3)
-Djavaws.sr.gateway.addr.0=localhost:8088
-Djavaws.sr.scope=C
-Djavaws.sr.main=com.inductiveautomation.factorypmi.application.runtime.ClientLaunchHook
-Djavaws.sr.runtimeOverride=true
-Djavaws.sr.project=test
And a main class name of com.inductiveautomation.ignition.client.launch.BootstrapSwing.
What should I put for the -cp argument? I tried using my module's client submodule. This allows the main class to resolve, but then throws this error on launch:
Error: Could not find or load main class com.inductiveautomation.ignition.client.launch.BootstrapSwing Caused by: java.lang.ClassNotFoundException: com.inductiveautomation.ignition.client.launch.BootstrapSwing
Update: In IntelliJ I allowed "Adding dependencies with 'provided' scope to classpath". This resulted in the following:
Initialization performed successfully JVM-wide ObjectInputFilter set up successfully Platform serialFilter has 88 pattern(s) Launch parameter "javaws.sr.main" missing.
Much like you had to create a custom pom for the designer launcher, you'll need one for the client "launcher". See the client-launcher pom example in the vision component SDK example:
That means you're not supplying the arguments I called out above as VM options - check you're in the right section of IntelliJ's run/debug configuration dialog, which is an utter disaster.
This opens the launcher, but it fails with the following message:
Error launching application: Validation Exception: JPMS Module opens/export check failed! check your --add-opens and --add-exports clauses
Yeah, you're going to need (probably) all the same add-opens and add-exports args as are required for designer launching.
I added basically all the args from my designer session and it worked like a dream. Thanks for your help!
Ok I am now having an issue with the first-party modules not loading. I was developing my module on an 8.1.41 gateway. During this development I had added the first-party modl files to the project library in IntelliJ.
Long story short, I decided to update my gateway to 8.1.48 which broke this classpath for some reason. I tried deleting that library and recreating it in the same manner, but to no avail. Is there something different about the 8.1.48 classloader that can’t see the .modl files on my classpath now?
Java cannot open .modl files. Ignition opens them and hands the contents to java at runtime. You cannot use the .modl files in your IDE directly.
I misspoke. I was actually using the jar files. When I recreated the library, I didn’t add the library path to all of the submodules of my module, which caused ClassNotFound errors for some pieces of the modules. In order to bring in first party modules, you must add the jars to all submodules of your build.
OK… now I am trying to do the same thing in VSCode. I have created a launch.json file with all the necessary VM arguments. I can now successfully launch the designer. However, I am struggling to make VSCode detect the jars of my module when launching, resulting in errors like this:
Hook class "com.test.designer.TestModuleDesignerHook" not found for module "TestModule".
I found that adding libraries to the classpath in VSCode is not actually being appended to the compiler/runtime classpath, but simply the language server used by IntelliSense. Any suggestions?
Edit: I added all the jars, starting with those listed in ‘lib/core’ and ending with those listed in ‘/jar-cache’ to the -cp vmArgument and everything works great.
Is this same sort of thing possible with Ignition 8.3? I know the module management system got somewhat of a rework.
Yes, the same basic principle should apply. Gone in 8.3 is the ability to submit new modules from your build system to directly upload them to the gateway and hot-reload in place -- but the approach generally talked about in this thread, where your IDE is directly running Ignition/the designer with your module code still works (and is what we use for development inside IA).
