Project Library Script Scope Issues in Gateway Scheduled Script
That usually means someone edited that script and introduced a syntax error. Or some other error is occurring at the top level, prevent it from being imported. Look in your gateway logs. Try making a trivial change in that script, and saving the project. If there's a problem with its automatic import, it should show up in the gateway log shortly after.
(Adding or removing a blank line at the bottom is a pretty safe trivial change.)
