Stop calling things this :X
[path for path, machine in zip(paths, machineIDs) if line == machine]
This also supposes paths and machineIDs are the same length.
If they’re not, it can be mitigated by using izip_longest from itertools:
from itertools import izip_longest as zipl
[path for path, machine in zipl(paths, machineIDs) if line == machine]
Now, I’m expecting the machines Ids to be unique (machineIDs could be a set).
Which means the resulting list will always either be empty (machine not found) or contain only one element.
If that’s the case, instead of using a list comprehension, which will examine every element, you can use next() and pass it a generator expression. Which is basically a list comprehension without the brackets:
this = next(path for path, machine in zipl(paths, machineIDs) if line == machine)
this will NOT be a list, but be the value of path for wich line matched the machine id.
If no match is found, it raises a stopIteration. Which you can use in a try/except:
try:
except StopIteration:
logger.warn("no matching machine id found")
OR, you can pass next() a second parameter, that it will return if no match is found.
this = next((path for path, machine in zipl(paths, machineIDs) if line == machine), None)
if this is None:
Note the added parentheses. That’s because with just one parameter, next() figures out that it’s a generator expression. With another parameter, you need to help it out a bit.
