Python List Comprehensions Help
Omit it altogether or return None? I ask, because how would you know which was which if it’s missing from the output.
EDIT: Or is at a summary, as @lrose just posted?
It is a summary as @lrose posted.
I think I put the code with the grouper def in wrong for testing. I got zero.
I also don’t understand a couple parts of the code that I will ask about.
I think I should learn to get the nested list for this input and output:
input:
infeed=[1000,2000,3000,0,5000,90]
outfeed=[1001,2001,0,4001,91,6001]
param3=[1.12,1.22,1.32,0,1.52,1.62]
param4=[3.1,3.2,3.3,3.4,3.5,3.6]
param5=[104,204,304,404,504,604]
bigList= zip(infeed, outfeed,
param3,param4,param5)
print bigList
Desired output:
[0.99,0.99]
I am getting no viable alternative for “if” as an error.
test=[[a[0]/a[1] if a[0]>100 and a[1]>100 for a in b]  for b in bigList]
and
test=[a[0]/a[1] if (a[0]>100 and a[1]>100) for a in bigList]
Ok,. if there is no ‘else’ statement, the if clause needs to go on the end. Also, dividing ints truncates the result. One of your values needs to be a float.
Combining the grouper recipe:
def grouper(n, iterable):
	return zip(*[iter(iterable)] * n)
# Usage example #
vals = [system.date.parse('2022-08-18 12:34:56'),
        1000, 1001, 1.12, 3.1, 104,
        2000, 2001, 1.22, 3.2, 204,
        3000,    0, 1.32, 3.3, 304,
           0, 4000,    0, 3.4, 404,
        5000,   91, 1.52, 3.5, 504,
          90, 6001, 1.62, 3.6, 604
groupedVals = grouper(5, vals[1:])
# You can print this, but it just shows the object.
print [float(x[0])/x[1]  for x in groupedVals if (x[0]>=100 and x[1]>100)]
Output:
[0.999000999000999, 0.9995002498750625]
ahhhhh
I can’t believe that I got hung on the “if” statement being at the end.
I kept thinking I had to use a nested list.
I didn’t even realize what the error code was saying till you said it too.
Thanks so much.
This is my current direction I am going.
After I finish, then I want to circle back and learn the code that @lrose posted.
I appreciate the help with this stuff.
print bigList
test=[float(a[0])/a[1]  for a in bigList if a[0]>100 and a[1]>100]
#test= "{:.1%}".format(test)
print test
#desired output [almost 1, almsot 1]
bigList=[a for a  in bigList if (a[0]>100 and a[1]>100)]
print bigList
qual=[ float(a[0])/a[1] for a in bigList]
print qual
[(1000, 1001, 1.12, 3.1, 104), (2000, 2001, 1.22, 3.2, 204), (3000, 0, 1.32, 3.3, 304), (0, 4001, 0, 3.4, 404), (5000, 91, 1.52, 3.5, 504), (90, 6001, 1.62, 3.6, 604)]
[(1000, 1001, 1.12, 3.1, 104), (2000, 2001, 1.22, 3.2, 204)]
update
vals = system.dataset.toPyDataSet(value)
infeed=		list(vals[0])[1::5]
outfeed=	list(vals[0])[2::5]
uptime=		list(vals[0])[3::5]
downtime=	list(vals[0])[4::5]
maxV=		list(vals[0])[5::5]
bigList= zip(infeed,outfeed,uptime,downtime,maxV)
infeed=		[ a[0] for a in bigList]
outfeed=	[ a[1] for a in bigList]
uptime=		[ a[2] for a in bigList]
downtime=	[ a[3] for a in bigList]
maxV=		[ a[4] for a in bigList]
infeed=sum(infeed)
outfeed=sum(outfeed)
rateXUptime=[a*b for a,b in zip(uptime,maxV)]
rateXUptime=sum(rateXUptime)
uptime=sum(uptime)*1.0/60
downtime=sum(downtime)*1.0/60
duration=uptime+downtime
def handleDivideZero(a,b):
	return 0 if (a and b)==0 else a/b
avail=	handleDivideZero(float(uptime),float(duration))
perf= 	handleDivideZero(float(infeed),rateXUptime)
qual=	handleDivideZero(outfeed,float(infeed))
#	value1=avail
#	value1=perf
#	value1=qual
#	value1=infeed
#	value1=outfeed
#	value1=uptime
#	value1=downtime
#	value1=rateXUptime
value="{:.1%}".format(avail*perf*qual)
return value
It is easy for me to read, and I think it is easy to analyze too.
I can highlight the commented out values and ctrl+/ to uncomment them.
Then I can make ‘value1’ into ‘value’ to compare the values to check on the machines.
Thanks for the help!
I am very happy with the code.
@lrose had some things I want to learn about if possible in post 140.
I think zip(*[iter(iterable)] * n) is putting groups of N into a list of lists.
I read that ‘*’ can be used to get values from a list without the brackets and commas.
I read that ‘Iter()’ lets you call next() to get subsequent values to a limit they call a sentinel.
I don’t really understand that part because iter() is used on iterable, the variable that is the original list.
How does the *n outside impact *[iter(iterable)] ?
If I had ["hello world"]*3 then I would have ["hello world", "hello world", "hello world"]
I think this is a matter of python syntax which I don’t know.
I would have expected repetition of the same values on the order of n repetitions.
I did not know a dictionary could be used like Sums, at least I think that is a dictionary.
I think I understand that part and thankfully I think I get the rest of list comprehensions below that section.
The grouper function makes use of the single-pass nature of iterators.
To get n copies of the iterator, it's put into a list, them multiplied by n. Note that this makes a list of references to the same iterator object. Every time you grab a value from the iterator, it goes to the next value, regardless of which copy of the iterator does it.
The '*' at the beginning is so we can unpack the elements of the list of iterators. and zip can work properly.
A list of lists (testList)
[['a', 'b', 'c'], [1, 2, 3]]
zip directly on list of lists
zip(testList)
[(['a', 'b', 'c'],), ([1, 2, 3],)]
zip after unpacking
zip(*testList)
[('a', 1), ('b', 2), ('c', 3)]
Here's a scipt to play with. Hopefully, it will give you some insight
vals = [
iterator = iter(vals)
a, b, c, d, e = iterator, iterator, iterator, iterator, iterator
for i in xrange(6):
	print next(a), next(d), next(c), next(d), next(e)
print ''
print '-----------------------------------------------'
print ''
iterator2 = iter(vals)
iteratorList = [iterator2] * 5
for i in xrange(6):
	for x in iteratorList:
		print next(x),
	print ''
print ''
print ''
iterator3 = iter(vals)
iteratorList = [iterator3] * 5
for x in zip(*iteratorList):
	print x
Output:
1000 1001 1.12 3.1 104
2000 2001 1.22 3.2 204
3000 0 1.32 3.3 304
0 4000 0 3.4 404
5000 91 1.52 3.5 504
90 6001 1.62 3.6 604
3000 0 1.32 3.3 304
0 4000 0 3.4 404
(0, 4000, 0, 3.4, 404)
value2='bz'
excludes=['p','y','z']
color = ['#AAAAAA' if x not in value2 and 'b' in value2  else '#FFFFFF' for x in excludes]
print color[0]
Why is this printing #AAAAAA instead of #FFFFFF?
Because 'p' is not in 'bz' and 'b' is in 'bz'. What were you expecting?
I thought that x would be 'z' when iterating.
'z' is in 'bz'
I think I am using something exactly backwards haha.
It eventually is...
value2='bz'
for i in enumerate(zip(excludes, color)):
	print i
Output:
(0, ('p', '#AAAAAA'))
(1, ('y', '#AAAAAA'))
(2, ('z', '#FFFFFF'))
value2='bhh'
result = [True if 'b' in value2 and x not in value2 else False for x in excludes]
color = '#AAAAAA' if all(result) else '#FFFFFF'
print color
Probably, I will do something like this.
Ok. It can be shortened a tad, since the comparison is already boolean.
color = [x not in value2 for x in excludes]
or, if you really want to go the one-line route:
color = all([x not in value2 for x in excludes])
Personally, I'd still keep them separate, as it makes for easier troubleshooting.
value2='bh'
result = ['b' in value2 and x not in value2 for x in excludes]
print value2
print color
Now I can check the id of the view, and color my navigation text while the path can have some level of redundant strings.
It seems weird to check every item in an 'exclude' list against a value, instead of the opposite...
Is it really what you want to do ?
I am not sure.
I need to check if the string contains one word and not five others to make an evaluation for sure.
So you want to check whether a particular string is in a list of pre-determined strings.
What you're doing with the code above is check whether those to-be-excluded strings match with your tested string, instead of checking if your tested string matches with one of the to-be-excluded strings.
Which actually makes a world of difference, particularly in how the code conveys what it's supposed to do.
def is_this_string_valid(test_string, required_words, forbidden_words):
	s = test_string.split()
	return all(w in s for w in required_words) and not any(w in forbidden_words for w in s)
req = ["foo", "qux"]
excl = ["bar", "baz"]
print(is_this_string_valid("foo", req, excl))
# > False
print(is_this_string_valid("foo qux", req, excl))
# > True
print(is_this_string_valid("foo qux bar", req, excl))
# > False
print(is_this_string_valid("foo qux bar baz", req, excl))
# > False
print(is_this_string_valid("bla foo something qux", req, excl))
# > True
Note that if you have only one required word, you can replace all(w in s for w in required_words) with required_word in s.
Note also that how you determine what a word is, is up to you. Here I just used whitespaces as delimitation between words. You might want to process things further.
I want to see if any values in a list are in a string I think.
I don't understand maybe.
What is the advantage of :
over :
Well... I suggest you figure out exactly what you need/want before you start coding ;p
Why do you say I don't know what I want or need?
Why do you talk to me like that?
I had posted code that did exactly what I meant it to do with Jordan's help.
Can you explain this for me?
I don't understand what you mean here either.
I don't know the advantage.
I think it's mostly readability though there may be a slight performance increase with using python keywords, in the same way you use list comprehensions instead of a for loop, there's a slight performance increase.
But I think readability is the big deciding factor over what you prefer. That and putting it inside a function so you can call it anywhere is a big advantage over hardcoding it.
That made me feel like you're not sure what your goal is. Sorry if I was rude, didn't mean to be.
One deals with words in strings, the other deals with characters.
Also, I find that using all() and any() makes it clear what is expected.
Actually your way was totally valid. I just find the logic kind of backwards - I'd tend to check if my string is in the list of strings to exclude, instead of checking if the strings to exclude match my string.
edit:
Here's a version that will handle characters, words, numbers, pretty much anything you throw at it, as long as values are in lists:
def is_this_list_valid(values, required_values=None, forbidden_values=None):
	req_check = True
	if required_values is not None:
		req_check = all(v in values for v in required_values)
	excl_check = True
	if forbidden_values is not None:
		excl_check = not any(v in forbidden_values for v in values)
	return req_check and excl_check
req = [42, 'foo', {'baz': "BAZ"}]
excl = ["bar", 21, 'a']
tests = [
	['bla', 42, 'b', 'foo', {'baz': "BAZ"}],
	['42', 'foo', 'baz'],
	[42, 'foo', 21]
for t in tests:
	print(is_this_list_valid(t, req, excl))
# > True
# > False
# > False
Might be simpler to just pass empty lists on call instead of using None as default, but... blah.
