I found some information on the pom.xml where you have to tell it to include the dependencies with the jar file. this just got to complicated because i had to find all my jar libraries i wanted on either github and add them as dependencies to my project pom or i needed to figure out how to install my jars in my local maven install then add them as dependencies in my pom.
<plugin>
<artifactId>maven-dependency-plugin</artifactId>
<executions>
<execution>
<phase>install</phase>
<goals>
<goal>copy-dependencies</goal>
</goals>
<configuration>
<outputDirectory>${project.build.directory}/lib</outputDirectory>
</configuration>
</execution>
</executions>
</plugin>
After thinking about this a little more what i did to make this process easier for me was just make a project where all it did was make the module free by adding the gateway hook with the isFreeModule function.
the output modl file then can be extracted and i can modify the module.xml file to reference my jar files i want to include and then compress all the files back into a modl file to be signed.
What was the reasoning for changing the a free module to need a gateway hook function rather than just reading it from the module.xml attribute?
