Below is the my expression for reading indirect tag to update the array value in power table.
runScript("system.dataset.toDataSet(['Slave', 'Value'], [[i,value] for i,value in enumerate(system.tag.readBlocking(" + {DirectTag.tagPath} + ")[0].value) if value > 0])",0)
I am using template that having power table with custom property of template parameter string to read tag.
Tag Info
Problem is tag is not reading through above expression and not fetching data to table.
Can we use system.tag.readBlocking() in expression?
Any suggestion much appreciate.
