Reading ControlLogix String Tags
The key is getting FT Linx to do the listening instead of RSLinx Classic. Do note that Emulate v32 and above do support various older firmware, too.
Just had this happen with Emulator (how I ran across this post). String tags were working before in Ignition, then when I restarted the emulator and Ignition today, the string tags came in as a folder. Ended up stopping and restarting Ignition through the command prompt and the string tags came up correctly again once Ignition was restarted.
Using Igntion 8.1.25 & Logix Emulate V35.00.00 w/ a V32 controller emulated.
Hope this helps.
