Reading modbus from Cisco IE4000 switch
Assuming you are using windows, open calculator, change to programmer mode, click on Hex and enter 1208 and it will return 4616 Dec
That’s for port 1 statistics number of packets received. Check with the Cisco UI the figure and play with Ignition until the value you receive matches. Common things to change are one based/zero based addressing and reverse word order
