Remove animation from progress component
What's the "persistence" setting on the props.value? If it's set to non-persistent then it defaults to 50 before it then loads the bound value. Although any setting will default it to something that most likely won't be your actual value. I'm not really sure how you would fix this... I think ideally you'd want it to start from 0
