Now I just need that elective studies thing for perspective, except 4 hours of tables and database manipulation instead haha
How do I set a status value of down for line 1 shift 2 for next Wednesday?
How do I then call to see what the status is for the 1st thru 3rd shift?
I get how to use the tag historian on the past. I don’t know how to set tag values in the future though.
Is there a scheduling component?
I didn’t see a section of videos on scheduling.
rewatching the sql section
I am still stuck on what is best to do for this.
Am I to make an sql table and put in every shift for the next two years?
I may get some time tonight (UK time) to go through this in a bit more detail. However, it’s back to legacy SCADA systems (which shall not be named here for fear of getting stoned to death
) for me today
ive not really worked with shedules, but my guess is you will need a db of sorts (could be a big dataset tag too i guess) to store in special dates/shifts that do not follow the normal trends.
And then for every date that is not in the database you use a default template or so in your ui/logic
I appreciate the help on this.
It has been put on the back burner for a while. I have a few projects ahead of it, so right now I am at least 3 weeks from getting back to this.
There is kind of a canned solution coming to me from a third party, but then also I wanted to make this customizable option. Just don’t have the time for a while.
that is a really handy set of ideas about handling a template and handling special dates separately
Sample Example
This might be coming off the backburner to the front for me.
Problem:
I have a branch location that is emailing a spreadsheet schedules.
One person has access to edit it, and they edit it in excel.
So I need a way to restrict access via scripting, which I think I can do.
I could just put a pass code to access the page with a script.
Then, I need a way to make a table functionally similar to Excel editing while also updating the database with each change.
How do I do that?
