Report Module Timeout
I can confirm that this is a much better approach to reporting. Generate reports during a low use time (especially very long running ones) through scripting...store them as PDFs into a database, then use @pturmel Blob Server module to present the PDF into a viewer as needed. Of course this only works for pre-generated reports. If you want ad-hoc reporting on the fly...you need to control how much data to show to not take too long or bog down the system.
