With the exception of some special cases (ahmmm QueryString parameters). You should almost always default to Named Queries.
Performance wise, I doubt there is anything more than negligible gains or losses between the two functions in a scripting environment. They both use the same JDBC driver, so the same queries will basically run exactly the same.
Although, I will admit that I don't know if Named Query caching applies to the scripting function or just bindings, so that could make a difference.
Best practice is more nuanced in this case. For performance when it comes to perspective see this topic:
For a reference of when you should use runPrepQuery over runNamedQuery see this topic
In short -
- If you can use a named query, you should use a binding if at all possible.
- If you don't need some type of dynamic SQL*, use a named query
- If you do need some type of dynamic SQL, use a prep query.
- If you are not using a competent DB engine (a.k.a MSSQL), and you need to provide an array of values (e.g.
SELECT * FROM table WHERE column IN (value1,value2,value3)) use a prep query. - If you need to batch insert, use a prep query.
*Dynamic SQL as in a user is providing schema level objects such as column names.
There may be other edge cases where a prep query is the solution, but for most general cases, just use a Named Query
