When you click the Run Action button (Double Arrows) does it give you an error?
Does the path and file name exist on the gateway machine?
Inductive wouldn’t let me post past 19 replies. I had to wait 19 hours.
Seems like an unnecessary requirement when this is a help and idea forum.
HourlyDTQuery = “C:\Path\ToFolder\Hourly_DT_Query.csv”
system.file.writefile (HourlyDTQuery,reportBytes,1)
It seems like that error was because write isn’t the function but writeFile is. It looks like you corrected that in your response here, but make sure that the F is capitalized if it is still giving you an error.
It Works !!!
I greatly appreciate every ones help. I learned very much.
Thank you !!!
For future help, you can press control-spacebar after a system call to get completion hints and proper capitalization.
type system. and hit control - space
type system.file. and hit control - space
etc.
Note the periods on the end.
Are you stopping then starting the Ignition Gateway Service after making conf changes?
Yes.
I close down the Designers and restart everything
Because it’s a network drive you need leading double back slash
Does your conf look like this?
wrapper.share.1.location=\10.36.16.36\wrapper
wrapper.share.1.target=J:
wrapper.share.1.type=DISK
wrapper.ntservice.account=nrb\caicrmetrics
wrapper.ntservice.password=Koyo1234
wrapper.share.1.account=nrb\caicrmetrics
wrapper.share.1.password=Koyo1234
You only have a single backslash at the start. Double it.
Also probably a good idea to edit your post removing the credentials. Just in case.
There are 2 \ before the IP, some reason when I copy and paste here it only shows 1
wrapper.ntservice.account=un
wrapper.ntservice.password=pw
wrapper.share.1.account=un
wrapper.share.1.password=pw
Try this, remember to stop and start gateway
Edited post to remove OP credentials
Use the pre-format button </> to prevent collapse of special characters and indentation in any plain text you paste here.
