i have no idea about the tag history i will try the script first ,if it can't be ,i will try tag history,thanks very much all
Oh no! You are using a user interface component to run your process!
Don't do that! Any disruption to your client will break your process.
Run your script in a gateway event.
I would use a transaction group for this (or a scripted equivalent).
I use a transaction group to store the following every ten seconds:
- actual count
- goal count (how many should have been made at that time)
- line status (we also have small stops in there)
This allows me to easily trend efficiencies, and caclulate uptimes / downtimes.
As an example, our line status is:
- 0 : running
- 1-4 : small stops
- 5 : down
- 6 : break
To calculate times (in seconds) the query would be something like:
SELECT line_status, COUNT(line_status) * 10
WHERE t_stamp >= '2023-12-11 08:00:00'
AND t_stamp < '2023-12-11 20:00:00'
GROUP by line_status
Where is the gateway event? for about the label text
https://docs.inductiveautomation.com/display/DOC81/Gateway+Event+Scripts
Have the gateway event update a memory tag.
Bind the label props.text to the memory tag.
