getCoreResults Is the correct method to access the results of a query type parameter in reporting.
Based on the fact that your table is showing as empty in preview, I would say that your tag history query is returning no rows. getRowCount() returning 0 would support with this.
Double check the parameter values being fed to the tag history query. Are you defining valid start/end times to the query? Is there actually data for the time span you are querying? Are you correctly feeding the parameter values to the query?
Also, post code as preformatted text to make it easier for others to review, please see Wiki - how to post code on this forum.
