Script error when running in gateway
Please consult this topic to fix your formatting when posting code:
As for your actual problem: Ignition by default runs as a "system" service account. This limited privilege account probably doesn't have access to your user folder. If this is a test only scenario, you can change the Ignition service to run as your user - see steps 4 - 9 in this section; ignore the MSSQL related pieces:
