Script to generate bindings
Fran, thanks for the link to my post. I don't think it's what Jose requires as it won't update if any of the tags change value.
I think the easiest option is,
  • Create a simple coordinate view with a tagPath parameter.
  • Add a Label Component to the view and create a tag binding on the label using the tagPath parameter.
  • Render the table's value column as a view and select the view created above.
  • Pass the tag path to the view instance.
You should be able to generate the list of instances by script fairly easily once you have the list of tags.
