Show the code you have, please.
Changed the code, got rid of the error, but it still will not change the tag values.
if event.source.controlValue == 'controlValue':
if newValue == 0:
event.source.bypass_on = False
event.source.bypass_off = False
elif newValue == 2:
event.source.bypass_off = True
else:
event.source.bypass_on = True
Be sure to use if event.propertyName == 'controlValue': at the top. the propertyChange event fires for every property that changes. The if statement acts as a filter.
Try what @pturmel posted
v = event.newValue
event.source.bypassOn = v == 0
event.source.bypassOff = v == 2
I think you need event in front of newValue
I changed Line 1 to if event.propertyName == 'controlValue': and it brought back the error code.
I saw what I did in the original. try:
value = event.newValue
if value == 0:
elif value == 2:
else:
